  • Replies 1.8k
Posted Images
I ordered one of these through ebay a few weeks ago and still havent received it.
have been emailing but havent really received a solution to not having my boost controller
does anyone know which user is the guy who makes them on here? so i can shoot him a pm?
Cheers
edited - bit worried, some people appear to have reported delays on delivery of this item
hey i know this topic is old but what is the boost controller called or could you link me, i wouldn't mind a new one cos mine spikes fairly shit atm... cheers
Edited by mspek
They have been nice enough to send me another after my first order didnt turn up after the first few weeks
so they are definatly alright to deal with.
the waits are a bit worrying though
payment went through april 29th, and came in the mail today.
just finished installing it, now waiting for the rain to clear so i can fine tune it.
very happy with the result of earlier boost, with boost beginning on the stock turbo at 1,800rpm!
will re-post with the results of boost spike and max boost rpm.
thanks for this product mark, will advise it to my friends.
cheers,
dave ;)
Just got it in the mail today, took around 1.5 weeks after payment which is fine. Took me 2 mins to install it, which includes binning the old atomic boost tap.
Came preset to 10psi. took it for a spin, virtually no creep at all. Only crept up to 12-13psi by the redline. Awesome product!
Have now set the boost to 7psi and it builds it instantly. Creeps up to around 8-9psi maybe around 6000rpm.
Highly recommended to everyeone!
Thanks simark!
my original one is still going strong after more than 2 years at 17psi with no spike and no taper off.
i am a firm believer that if you get your boost pressure from about 35cm away from the turbo compressor housing there is less turbulence and a steadier boost pressure.
I noticed spike when i was getting boost from the nipple on the compressor housing.
  • 1 month later...
meh i got two here i just removed from customers cars.... pretty good for a bleeder (yes it is still a bleeder) but cannot come close to a ebc. i should post up some comparison graphs.
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
