Ok as topic says, i just replaced my front and rear brake pads, wasnt hard at all.
Below i got step by step procedure on how to change the pads for those of you who want to save some money and learn something.
1. Get your self an R32 gtst skyline
2. Did the rear brake pads first so make sure you put bricks or a heavy object infront of the front tyres so it doesnt move forward while you raise the car on the jack and proceed to take off the wheels. Once the wheels are off you should see
Ok, There are basically two ways you can change the pads. One, you can take off the whole caliper by undoing two bolts at the back OR Two(easier), leave the caliper on. I'll show you both ways, first way we will take it off.
3. Undo the two nuts behind the caliper with a size 17 socket. The second bolt you cant see in the pic, its just underneath.
One both have been undone the whole caliper should come off. Now the parts we are going to take apart are labeled 1.Bent pin 2.Long pins and 3.X Plate
4. Now carefully pull the bent pin out, very easy but careful not to bend it. Once you have done that, you can pull the two long pins down and they should come out easy. Just be careful when your taking out the long pins because the X plate might spring up and go flying some where
After you have done the last step the pads should easily come out. If your worried about the piston coming out of the caliper dont worry, unless some one jumps in the car and pushes the brake pedal in.
5. Take the back metal plate off the old pads and put them on your new rear pads
Ok when i got to this stage, i needed to push the pistons in the caliper back and it cant be pushed back by your thumb...i tried and it didnt work hehe...with limited tools my macgyver in my came out and i thought of this idea. I bolted the caliper back to its original location, then using a big philips head screw driver i pushed the head of the piston back with the help of the disc
Ok you know how i told you earlier theres an even easier way to replace the pads, here it is. Once you have moved the pistons on both sides of the caliper back, the new pads should just slide right in, so yes...there was no need to take off the caliper to begin with BUT i didnt know and i found out after i changed the rear right brake :P
6. Line up the pads with the holes and insert one of the long pins to hold the pads in place. Next get the X Plate and place it back, please see below pic how 1 of the legs is behind the pin, push the other leg of the X back while you insert the second pin.
7. Once both long pins are in, grab the bent pin and feed each side into the top pins like how it was in the begining and thats replaces the rear pads.
With the front pads it is exactly the same thing tho i had four pistons to push back rather than two because my R32 is the type M modem with bigger front brakes. 1.the long pins 2.X Plate and 3.Bent Spring
Now after you have done all your brakes, go read Brake Pads - Bedding In Instructions - by GenesisR32
thanks
-Barny
Hi Barny
I'm keenly waiting to see how it went. Would you mind also posting what tools you used and how much time it took you? I'm guessing when you say brakes you mean changing the rotors or did you mean pads only?
Cheers
Mark
Also, if you need to replace the disc it is also easy.
Follow Benny's instructions to step 4, ie take the caliper off the disc. At this stage you can simple remove the disc and replace it. If you are doing the rear disc there is a small handbrake drum in the middle so you need to take release the handbrake first. When you put the new rear disc back on you may need to adjust the drums as well.
Yep exactly the same, and for 33 and 34 GTRs as well :) Its a pretty easy job.
Having said that, if you are not sure, don't do it yourself, nothing worse than the brakes not working......
  • 1 year later...
  • 2 months later...
just thought id mention what id learnt the other day off my uncle while changing my brake pads, to push the pistons back in you could use a G-clamp, which makes it much easier
Mate did that with the rears on his 180SX but they were the screw in type and broke the clamp! :D
  • 1 year later...
this is awesome fun just completed it this arvo.. real bonding moment with your car.... if u have spare time also give it a few coats of any desired colour followed by clear coat..(use caliper paint as it will take the heat) plus a real clean up so the paint sticks
all up did rotors pads and a lotta coats of paint!! well worth it!
good luck
:thumbsup:
  • 3 months later...
Just a heads up. I find it easier to push the pistons in if you release the bleed nipples on the caliper. Make sure that you either bleed them afterwards or have a hose on the nipple so it sucks in brake fluid instead of air. Also if you don't do the bleed nipple method and just push the caliper pistons in to loosen the master cylinder fill cap. I find it helps a little and makes it easier to push the piston in. Note that if you have added brake fluid in the past ie noticed that the level in the master fluid is low and added more you may find that brake fluid has spilled over the master cylinder brake fluid container when you push the brake pistons in ( keep an eye on the level when you push the pistons in ). Brake fluid is no good for your paint work. So have a wet rag ready and wipe up any brake fluid that gets on your caliper or paint work. Don't get any water near the brake fluid container because water will ruin brake fluid and will need to bleed from the system.
An even easier way to push the pistons back in is buy a small metal bench vice from your local hardware shop, then cut the clamping faces so they are the same width as the top of the caliper where the pads slide in then insert the vice into the top of the caliper and slowly wind the handle so that the vice pushes the pistons back.
Works extremely well, very fast and only cost about $15.
  • 1 year later...
  • 4 months later...
  • 1 year later...
  • 2 months later...
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
