since i cant offord big flash new brakes i decided to dress up my crappy old calipers, i went and bought some dupli-color, metalcast anodized paint, i selected blue took it to the counter and the guy told me i needed the proper primer for it, i thought he was just tryin to scam me, but you do actuly need it to create the shinny reflective anodized look, i painted them and they turned out really good since my rim's have already got anodized blue in them they matched really trick, it is heat proof specificly for calipers and rocker covers ect ect, im gona do my valve cover also so ill let yas know how it turns out, but its really goot for dressin those dull parts up,
https://www.sau.com.au/forums/topic/73794-how-to-anodize-your-brake-calipers/
  • Replies 182
that looks cool! You did a gr8 job.
Im gonna do mine either gold or red one of these days.
Hopefully they'll turn out as good as urs did.
cheers man, i had them a flat blue before, but was so dull, it comes in red gold green, heaps of sick colors, all i did was give them a sand down till was smooth, then got mag cleaner to get all the brake dust of, then just prepsol, left them to dry, 4 coats of silver primer, 4 coats of blue, just one thing, make sure you get all the brake fluid out of the caliper cos it can oozz out 1/2 way through and wreck it, and also becarful the brake line is clean when reattatchin it,
should i be taking the calipers off ?? or did you just cover the brade pad thingy at the top ?
so you sprayed it with primer heaps, then the actual paint ?
How many cans did you go through to do the front 2 ?
Now the question is.. what color do i want to do em ? my cars black with white wheels.. Im not good with decisions :D
yeah u take them of completly, i went through 1 can of primer stuff, one can of blue for the frount, and still got enough for a 3rd i recon, with ya car i recon a gold would look ok, whatever ya color scheme is, i recon black and green go ok too, but dono if they will suit the white rim
sorry for being anoying :)
if the take the caliper off, is it easy to put back on.. like there wont be any alignment issues etc etc ?
na mate just 2 bolts and the brake line, then to put back on just seperate the pads, and put bolts and line bak on, that easy, then bleed ya brakes all good
They look great, they're a lot shinier than my blue calipers. When I did mine I used VHT brake paint & finshed with a glossy top coat.... but, I want yours dammit :) . I might have to try this dupli-color metalcast anodized paint when I do my rocker/ cam covers.
They look great, they're a lot shinier than my blue calipers. When I did mine I used VHT brake paint & finshed with a glossy top coat.... but, I want yours dammit :rofl: . I might have to try this dupli-color metalcast anodized paint when I do my rocker/ cam covers.
yeah its a wiked paint, they turn out soooo dope, and i think its cheaper then normal stuff, i had that cull vht crap b4 but this is the stuf ya want
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
