since i cant offord big flash new brakes i decided to dress up my crappy old calipers, i went and bought some dupli-color, metalcast anodized paint, i selected blue took it to the counter and the guy told me i needed the proper primer for it, i thought he was just tryin to scam me, but you do actuly need it to create the shinny reflective anodized look, i painted them and they turned out really good since my rim's have already got anodized blue in them they matched really trick, it is heat proof specificly for calipers and rocker covers ect ect, im gona do my valve cover also so ill let yas know how it turns out, but its really goot for dressin those dull parts up,
https://www.sau.com.au/forums/topic/73794-how-to-anodize-your-brake-calipers/
  • Replies 182
that looks cool! You did a gr8 job.
Im gonna do mine either gold or red one of these days.
Hopefully they'll turn out as good as urs did.
cheers man, i had them a flat blue before, but was so dull, it comes in red gold green, heaps of sick colors, all i did was give them a sand down till was smooth, then got mag cleaner to get all the brake dust of, then just prepsol, left them to dry, 4 coats of silver primer, 4 coats of blue, just one thing, make sure you get all the brake fluid out of the caliper cos it can oozz out 1/2 way through and wreck it, and also becarful the brake line is clean when reattatchin it,
should i be taking the calipers off ?? or did you just cover the brade pad thingy at the top ?
so you sprayed it with primer heaps, then the actual paint ?
How many cans did you go through to do the front 2 ?
Now the question is.. what color do i want to do em ? my cars black with white wheels.. Im not good with decisions :D
yeah u take them of completly, i went through 1 can of primer stuff, one can of blue for the frount, and still got enough for a 3rd i recon, with ya car i recon a gold would look ok, whatever ya color scheme is, i recon black and green go ok too, but dono if they will suit the white rim
sorry for being anoying :)
if the take the caliper off, is it easy to put back on.. like there wont be any alignment issues etc etc ?
na mate just 2 bolts and the brake line, then to put back on just seperate the pads, and put bolts and line bak on, that easy, then bleed ya brakes all good
They look great, they're a lot shinier than my blue calipers. When I did mine I used VHT brake paint & finshed with a glossy top coat.... but, I want yours dammit :) . I might have to try this dupli-color metalcast anodized paint when I do my rocker/ cam covers.
They look great, they're a lot shinier than my blue calipers. When I did mine I used VHT brake paint & finshed with a glossy top coat.... but, I want yours dammit :rofl: . I might have to try this dupli-color metalcast anodized paint when I do my rocker/ cam covers.
yeah its a wiked paint, they turn out soooo dope, and i think its cheaper then normal stuff, i had that cull vht crap b4 but this is the stuf ya want
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
