***Located in SA adelaide***Hi guys....my car r33 gtst s1 is currently in the workshop having a HKS 2530, dump and frontpipe + high flow cat fitted to replace the stock parts. Hence, by monday, I will have the turbo all the way to the cat ready for sale to anybody!!!
The R33 GTST turbos have always been good upgrades for r32s :rofl:
By late next week, I will also have the r33 afm + ecu + injectors (375cc), for sale as well!!!
Turbo is in very good condition! No smoke and pushing my car hard even at stock boost!!! This turbo has never has boosted as I do not dare boost a stock turbo. I will be boosting my hks2530 though :wassup:
Currently, forsale:
r33 Series 1 stock turbo + dump pipe (90ks+) $400 firm(perfect condition)
r33 front pipe $30
r33 hiflow 3 inch catalytic converter $200
rb25det stock fuel pump $60
r33 stock injectors 375cc X 6 $100
Some more bits are currently on my car still and not forsale till late next week.
If you want them, you can express interest and book them so you'll have 1st priority once they outa my car next week!
r33 gtst manual ECU $70
r33 gtst air flow meter $70
Pictures will be available next week when my car comes back from the shop!!! All items guaranteed in good condition as I take ultra good care of my car!!!
***Note***All prices stated are negotiable****I hope the prices are reasonable
Okay...I got some offers for the turbo already...all offers will be considered
As Im no trader, i don't know the 'market' price; Hence please feel free to quote me any price for any items on sale.
I am a very friendly guy!
  • 2 years later...
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
