this is in regards to my exhaust set-up...
currently:
- 3" dump/front-in-one (from BATMBL)
- 3" custom-made mandrel-bent cat-back with 3" cannon muffler and 3" resonator
- stock compliance cat: looks like 2.5" but has been 'high-flowed' if you know what i mean...
so my question is this:
is it worthwile spending the $200 on a 3" cat?
I have done some searches and have read many posts where people change to a 3" cat and say they feel no difference in power...
another option is to get my cat 'converted' to a 3" cat by cutting it and welding on 3" flanges and 3" pipe on either end...
is this possible? has anyone done this before or is it just theory?
has anyone chagned their cat with positive results?
with this set-up i made 132rwkw on 12psi with the auto-trans equipped rb20 (with 10-10.5 AFRs!)
Cheers,
Warren
https://www.sau.com.au/forums/topic/74133-25-cat-to-3-cat-worth-it/
depends on how much boost your going to run, id say with your setup and only being 2litres you might not gain much.  But at the end of the day the bigger freer flowing system wont hurt.
that's what i'm thinking... i don't want to spend $200 to find it makes no difference. that $200 could go into an SAFC or something similar...
anyone else actually done a swap and noticed a difference?
Not that im hijacking the thread or anything, but since where on the subject of zorsts and size...
Is there much improvement for a 3.5" over a 3" turbo back on an rb20 making 200rwkw ??
Is the extra 0.5" really worth it ? if so how come few people have them...
well, yeah you are hijacking the thread. you will get more responses if you start a new thread...
Alternative.........spend $500 and upgrade to a 4" Magic cat, no restriction there:cheers:
there may be no restriction, but my question is will it make any difference in power?
being a studenti'm after bang-for-buck
$500 for a 5kW gain is not worth it in my book... however $500 for a 20kW gain is a different story... but i know in this case that's not what i am looking at
if you have already 'high flowed' your 2.5 inch cat just stick with it. it will flow more than a 3 inch 'regular' cat. though you are breaking the law and for fine prevention it may be worth looking at a 'proper' high flow cat.
yeah its just a temporary measure untill i can get my hands on something better...
thanks all for you help :)
might just save up for a 3" cat in the next few months...
how would they tell your cat had been "high flowed" though if it still has the original housing? I mean its not like a cop is going to pull you over and take your cat off and then defect you.
well that's a debatable point... some say they "have a method" but i have not heard of anyone getting fined
i think the $10,000 fine that you can potentially get scares some people away
It would have to be a very long and very flexible broomstick to snake its way through your muffler, resonator and around any bends in the exhaust.....
I have "heard" of people hacking the ends of their 2.5" cat and putting a 3" pipe straight through and then welding 3" flanges on the ends.
yeah i have heard stories of it too but never actually spoken to anyone sho has done it
i think its just a myth
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
