how much did it end up costing him, and how much was compliance as imports 101 are importing a r33 for me 2
i think in the end aound the 22k mark ,as for comp i cant tell u i will ask him next time i see him
but that did include new 18 inch tyres and some paint work
$400 tyres
$900 paint (ouch)
he wasnt to happy when he saw like 20 skylines in the autotrader for under 19k
I think you will find he said is he needs a hand controller to tune it as he doesnt have the laptop software. I've seen him tune many with a laptop.
i kind of question that myself and it made sense
but the base software programs are available as a free download of the net as are most known ecu maps
u have a better option with the software wouldnt u say
a controller was only a added option for the power fc
Ok, I have to come out with some defence now..............
The day my car was cleared by customs I seen it, and while I was there, so with this one in compliance spec. That was 2 months ago, so it seems there must have been problems with the car that it wouldn't/didn't pass the pits, such as the one you've mentioned, over-boosting etc. I don't want to sound like a prick but buying a car with those mods that looks like that is a risk, because it would have been thrashed, and your mate should have known about the risks involved.
And if you're going to mention bad things about businesses don't mention their names, it's against the forum rules, especially if they are about problems that were possibly there before.
Tell your mate good luck with getting it all fixed, I would advise him getting it tuned proffesionally ASAP, otherwise that could lead to even more problems nobody wants to see!! Check the sponsors thread about Hyperdrive, see if they could help him out.
mine car 2 also took along time to compliance at the aboved mentioned workshop..... bad choice of compliance place pm for details.
The workshop you mentioned has (Along with many others) had a huge (& short lived) increase in the volume of work due to the carry on with the 15 year rule. It is calming down somewhat now & the business involved is moving to new, larger premisis.
Danny is doing a huge number of hours per week to try and keep up, but there is only so much he can do.
It is also worth remembering the RAWS/SEVS compliancing requirements and what you are allowed to get away with in terms of engine mods - ie very little. So a car with alot of mods is going to take longer to comply.
I have put two cars through this workshop & am happy with the service & the approach to doing business.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
