hey richo, had exactly the same problem man. Went down to Autosport on Magil road, they don't stock HKS, but what they did do was measure my orginal filter and then had an exact replacement made out of the UNIfilter element. Pulls just as hard as before, if not better, and best of all is completely washable and reusable, unlike HKS. Gets better though, price...$35! PM me for details and I'll put you on to the guy I dealt with, he's really good!
https://www.sau.com.au/forums/topic/74197-hks-pod-filters/#findComment-1363722
cheers Richo, but not my car anymore...sadly. Imported it as is from Japan about 2 years ago, had it here for a week not even complianced yet and someone else saw it in the workshop and made me an offer I couldn't refuse, so to speak, lol. Last I heard it got sold interstate, but yea it was sweet looking! At the moment I've got a TT Soarer, doesn't handle like a Line but plenty of balls and you can't beat the luxury!!
https://www.sau.com.au/forums/topic/74197-hks-pod-filters/#findComment-1364801
why does it have to be the hks one? like mxt said, so witht he store at magill. Seems like a bargain to me.
It takes 2 weeks to get the replacement made with the guys at magill, and I need it before that.
But yes it is a great deal and if i can't find it anywhere else, I'll have to go with them.
https://www.sau.com.au/forums/topic/74197-hks-pod-filters/#findComment-1365951
two weeks. that sure is a long time.
https://www.sau.com.au/forums/topic/74197-hks-pod-filters/#findComment-1366496
Give Jap Tech Imports a go on 8266 0212.
Funny guy this one. offered me "HKS" complete units from 70 to 120 dollars depending on the quality I want, :werd: Correct me if im wrong but aren't they all the same price and quality and about 200 - 250 for a complete unit?.
So I explained to him that I was just after the replacement to which he replied: no mate dont have the replacements in stock , but try KMart they sure have them... WTF!! :alcoholic
https://www.sau.com.au/forums/topic/74197-hks-pod-filters/#findComment-1367384
:bahaha: :P :bahaha:
I did source one from them when I had my HKS pod it was about $60 for replacement (the 15cm one). Well I don't think Ill be goin to them for anymore parts, when I can just go to my local Kmart :(
https://www.sau.com.au/forums/topic/74197-hks-pod-filters/#findComment-1367703
Thanks to pkblade after all, :D
Finally got my filter element today, at JMS, they got some in early this week and already have about 3 left, after speaking to the guy there it appears they are gonna keep them in stock regularly, but is not for sure, So if anyone was to get some, better hurry! :)
https://www.sau.com.au/forums/topic/74197-hks-pod-filters/#findComment-1374490
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
