Very interested in a comparison between the HKS 25/30, HKS 25/35 and Rb25 hi-flowed turbos!! (http://www.gcg.com.au/Catalogue_Menus/Upgr...pgrade_gtst.htm)
Im also interested in spooling times, mid-range and max power figures on an rb20 from these...
Im guessin the 30 will spool quicker than the 35 but not have the same peak power ratings? Interetsed to know where the GCG hi-flowed rb25 turbo would come between these two turbos.
Anyone know??
Also another thought... what about a HKS GTR-S in terms of lag and max power?
GT2530 results update
http://www.skylinesaustralia.com/forums/sh...ght=2530+Hiflow
HKSGT** head to head with GCG H-flow
RB25 turbo ugrade, ALL DYNO RESULTS
http://www.skylinesaustralia.com/forums/sh...hlight=HKS+2530
Rb25 Hks2535
HKS GT2530 turbo question
HKS 2530 on RB25 Wrap Up
[iNFO] Before & After GCG Turbo Hi-Flow
GT-RS or high flow?? opinions??
HKS GT-RS Installed
Fitting a hks 2530
HKS GT2535 - Optimum efficiency band ?
The Ultimate Turbo for your RB25DET
HKS 2540 on RB25DET result
HKS 2530 Dyno Results
Hks Gt2530
high flow or aftermarket turbo for r33
What boost to run for a HKS 2530
GCG or HKS 25** Turbo
HKS 2530 on a R33???
HKSGT2530 Results on RB25.
From what im reading im getting that impression too..
220rwkw on a tired rb20 (170,000kms) and 265rwkw on a neo rb25. Shows the turbo can produce the goods and has plenty of scope left! Dont see many 2530s making more than 300rwhp really.. this turbos done 355rwhp on that rb25! So probably 320+rwhp on a good condition rb20.
Although expensive i think i will go with my first idea the GCG 450hp hi-flow...
and a few other little goodies...
Im personally looking for anywhere around 300rwhp out of my rb20 with a turbo thats not TOO laggy... the GCG rebuild looks the go as it can push alittle more hp outta it where as the gt2530 cant. Thought about the 25/35 but this seems too laggy..
Whats ur thoughts dude?
Id go a stock hi-flo turbo for sure with a set of tomei poncams.
gt2530 for the rb20. high flow for the rb25.
"i think the hiflow makes more power and also spools up quicker"
i dont see why the highflow would spool up quicker, the 2530 spools pretty quick! Id actually say the 2530 would spool up quicker, going on runs ive had with garret equivalents.
I believe a 2530 on an RB20 would be an OK upgrade.
But on an RB25 I have found a small problem, it boosts up at cruise (100 kph) as soon as I squeeze the throttle. This is a bit annoying when driving along any freeway with hills, I squeeze a little bit to get up the hill and it boosts up and accelerates too much. I back off so as not to go over 110 kph, then I slow down too much. It is hard to keep at a constant speed and it definitely uses more gas.
The GCG ball bearing hi flow doesn't do that, you need to give it a bit more on the throttle to boost up the hills, I don't have to flatten it or change down, just an extra few mm of pedal travel. It is so much easier to keep at the set speed and it uses less gas as a result.
Since we race interstate 9 times a year, this is important for my usage patterns. Maybe not so for others.
:P
SK thats right about the quick boosting up, and i agree this can be annoying when you want only a bit of acceleration rather than a surge, but it can also be fun and give the car an effortless feeling of power from boosting point thru midrange, eg. for overtaking you just need a tiny bit of throttle and you whoosh by.
Yeh, but how much is " tiny bit of throttle"? I am going to waste a bucket load of fuel if, every time I move the pedal ~1mm, it boosts up. I reckon ~5mm is good, that gives me ~4 mm to adjust speed, without surging away. After all I have ~50mm left to demonstate effortless acceleration.:)
Each to there own.With a RB20 we need all the poke we can get :) (Don't worry Roy I love the RB20)
I'd rather squeeze the pedal a little and for it to take off but it aint going to happen.So the RB25 is that much of a different animal?
its just that i already have a gcg hi-flowed turbo on my rb20, and was just wondering if a 2530 is better....i just want a good power result, the car has a hks front mount, apexi 3.5inch exhaust (turbo back), bosch 040 pump, 14psi, the stock computer chipped in japan b4 i got the high flowed done to run heaps of boost. stock injectors.....i just want to know how to get more power with this turbo...im currently lookin for a power fc and a set of poncams and injectors...will these parts give me alot more power than it has now or would i just expect a little bit?
sry for so many questions
What sort of hi flow? There are hi hi flows and low hi flows.
I have a GCG Ball Bearing Hi Flow that flows enough air for 265rwkw on an RB25DET at 1.4 bar with Tomei Poncams, Std R33GTR intercooler, split dump, 4" cat, 3.25" exhaust, Nismo injectors, Std R33GTR fuel pump, Power FC and Z32 AFM. It has more power EVERWHERE than when it was standard.
I have not been able to get within 30 rwkw of that with a 2530, but it might make a little more down low, not much I suspect.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
