187 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I've driven Nissan's for quite a while now and have Always been impressed with their packages. I used to have an R33 GTS-T for a few years before the R32 GTR, and whilst I'll probably keep my 32 for quite a while to come, one always wants to expand their driving experiences. As we are ALL motor enthusiasts and as such appretiate what other manufactures have to offer.
So what do you guys think and how do they compare, I know they are apples and oranges.. though they still can be picked up at relatively the same price. What would you take for a year or so for a (different) and good car for spirited driving through the hills and streets etc?
FD3S RX-7 Series 6
Mitsubishi Lancer Evolution VI
Cheers
https://www.sau.com.au/forums/topic/74623-fd-rx7-or-mitsubishi-evo-vi/
  • Replies 70
evo vi vs s6: evo vi
evo vi vs s8: s8 (that's an s8 (or a kitted 6) that is pictured above, btw)
evo vii vs s8: evo vii
s6 is a bag of worms - definitely do some research before heading down that road (take my word for it!). s8 is the perfection of the 3rd gen FD (though still requires research and caution if you want to mod).
Both cars are pretty much on par when it comes to performance and ability - though the driving experience is poles apart. The FD is a real "drivers' car", while the later evos largely run the show, as opposed to the driver.
The FD is definitely cheaper in terms of bang for buck (despite the common misconception that anything twin turbo is horribly expensive to mod) - as long as it is done wisely.
Having ridden in an evo vii - I can say that it is one of very few japanese cars that I would swap my car for. Aesthetically, however, I'm not a big fan of the viii.
Evo any day - it might not have the straight line power like the rx7, but take it to the G.O.R and bye bye RX7.
Evo is the complete package for sure, and i must agree with Bluprint - Evos have that tough sexy look to them.
Mate, RX7 FC/FD's smoke any car in the hills...
FD's handle better then nearly every jap car ive driven.
FD in my opinion. Personally I would get one in Yellow like Keisuke's from Initial D. I drove behind a red RX-7 at a car cruise on some twisty roads and it seemed to handle like a dream from my point of view. FD's are pretty rare on the streets as well.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
