Hey guys will be launching my new buiness in September starting out as group fitness and personal training and in march expanding to massage therapy and nutrition later next year, slowly adding services eventually adding physiotherapy and stuff when I finish uni :-) www.melhealthandbody.com yippee!
Do you have any good Hypnotherapists in Canberra Melly?
I've had several clients from the ACT of late - mostly for smoking, phobias and compulsive eating. Clients refer more clients and I don't knock them back; but I'm also copping the odd enquiry, "Isn't there anyone closer?"
Cheers
  • 5 months later...
import parts turbos motors, gearboxes, wheels, tailshafts, panels, bars, lights, bolt on's, full cwest body kits, trim pieces, and a shit ton moreand we have the abbility to fit them
Noice... Can you get me an R33 4door Roof Spoiler? Heaps keen.
Just thought I would let you guys know Japspec has this on their page,
Japspec wants to let everyone know we are going to open our doors for a short time only for a fire sale... We have parts ranging from bodykits, to hubs, ecu's, looms, for Nissan's, Honda's and Mitsubishi's, everything must go, we will not be answering the phone for prices we do not have the time nor patience. You must come in with CASH to get Fire Sale prices.
owned this. was very happy. Decided it's big brother would make my grin bigger
HKS 2530, external coils, FMIC, Microtech ECU, Veilside front bar, Recaro's etc.
I still miss the Original S!N
  • 3 months later...
Internet -DIY, Best detail you can do. Seriously. Most places will just take a mind cut and polish to it and ruin the clear. Is it a new car as in Brand new or new as in second hand? lol if that makes sense...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
