Easy mate, meguiars next gen tech wax 2.0 other than that keep it clean with washing it. Since it is a new car you don't need to use a clay bar/Take it to a detailer. The meguiars wax is REALLY easy to use.
  • 4 months later...
Don't take it personally to heart and make a big deal. Said in fun with a bit of truth.
Like lawyers being sharks, like car salesmen being slimey.
It means I am cautious with Real Estate agents.
Do they represent the seller or the buyer? The easy answer is the person who engages them.
The real answer is that they are in it for themselves.
Personally I dislike Sales .....
:P this emoticon means Jks.
Oh oh oh - And the guy who started this business thread in 2005 (Andrew) he was a successful real estate agent :thumbsup:
he was a great guy. Liked to look after his appearance a bit too much tho. The true Metrosexual.
His favourite colour was pink !
One night at our regular trivia night the whole gang wore PINK shirts about a dozen skyline owners - big laughs had :D
The list Vielside is Andrew
LIST:
VeilsideR33= Real estate agent
R31DET= ex car detailer and car artist, works for Ingrams Auto Electronics & Air conditioning
Supaflyskyline= electrician
R31_Silo2= Jeans west
4PKNUP= Target (the T is silent)
Terminal= Engineer
Amaru= Network Engineer
NJR 34GTT= IT Specialist with IBM
Bluprint= Web developer
Stevie= Public relations
Frink= ABC T.V and film and T.V guru
Oscar32= Child psychologist
OZR32GTR= IT Consultant
Leech_ = Network engineer
Sauce= Coles and studying 3D
Race_snooze= IT and ex Air-conditioning tech
skyGTRline= Southers ****
djhatton= Electrical section at domayne
bambinator= Doctor at Canberra Hospital
Anakha= Royal Australian Air Force
Yeti= Lawyer
Biancardi= Tiler
Marc2= Owner of dicount tyre service, Belconnen and Gunghalin and they are also authorised inspection stations, call 62515977 and ask for Mark. Fitter and turner, Mechanical & electrical engineer
SKYLVIA (Beau)= Electronics boutique
Matski= Commercial broadcaster
Noony= I.T security
LTSJayce= Athletes foot - Belconnen
Edited by Sinista32
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
