compliance plate
GR33DyMANGO,
I can get the phone number for you, but I wouldn't waste your time. Unlees you know someone personally over there they won't give you the time of day. Most dealers over here spend years getting to know some of the people in Canberra, just so they can get plates back quicker.
It is usually better to wait and see. Takes about 2 weeks, how long have you been waiting?
See'ya:burnout:
https://www.sau.com.au/forums/topic/7478-compliance-plate/#findComment-109509
Hi Guys,
I'm helping Justin off-forum, to avoid naming names, but for the rest of you the following may be useful.
The actual compliance plate itself comes from Niddery Nameplates in NSW, once you have approval from Canberra then it should only take 3-4days. You will need the CPA No., which is the compliers number, and the chassis number of the vehicle, in order to findout details.
The contact number is: 03 9335 2977
Hope that helps people. The plates are only created once approval from Canberra has been granted.
See'ya:burnout:
https://www.sau.com.au/forums/topic/7478-compliance-plate/#findComment-109602
Once the form has been OK'ed by canberra, then you can send off for the compliance plate, they are two separate things. One is the form detailing that your car meets the austrailian standard and granting permission for the compliance, the other is the plate to attach to your car, but it can't be applied for without the form from canberra.
It is usually canberra that drags there feet.
See'ya:burnout:
https://www.sau.com.au/forums/topic/7478-compliance-plate/#findComment-109613
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
