compliance plate
GR33DyMANGO,
I can get the phone number for you, but I wouldn't waste your time. Unlees you know someone personally over there they won't give you the time of day. Most dealers over here spend years getting to know some of the people in Canberra, just so they can get plates back quicker.
It is usually better to wait and see. Takes about 2 weeks, how long have you been waiting?
See'ya:burnout:
https://www.sau.com.au/forums/topic/7478-compliance-plate/#findComment-109509
Hi Guys,
I'm helping Justin off-forum, to avoid naming names, but for the rest of you the following may be useful.
The actual compliance plate itself comes from Niddery Nameplates in NSW, once you have approval from Canberra then it should only take 3-4days. You will need the CPA No., which is the compliers number, and the chassis number of the vehicle, in order to findout details.
The contact number is: 03 9335 2977
Hope that helps people. The plates are only created once approval from Canberra has been granted.
See'ya:burnout:
https://www.sau.com.au/forums/topic/7478-compliance-plate/#findComment-109602
Once the form has been OK'ed by canberra, then you can send off for the compliance plate, they are two separate things. One is the form detailing that your car meets the austrailian standard and granting permission for the compliance, the other is the plate to attach to your car, but it can't be applied for without the form from canberra.
It is usually canberra that drags there feet.
See'ya:burnout:
https://www.sau.com.au/forums/topic/7478-compliance-plate/#findComment-109613
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
