  • Replies 44
You two can go serve yourselves a big dose of GAGF! :(
Ben - yeah Chris and Frank will be there. Apparently Franks been cheating (aka - Ben's had it recently for "improvements") so if it's dry I can see a sub 1.20 from him. There's a new R34 floating around that I can see quickly passing me as well unless I pull the finger out. Will have to try and keep him behind me for this event at least.
From what I remember, he said he was out on a bit of a cruise and while passing Calder decided to give it a run.
He had to borrow long sleeves from someone coz he was wearing a tshirt (as always).
He did his 11 and drove out and continued cruising.
Leewah ............... you forgot that Ben also run 136mph, 21 psi on pulp, semi-comps 34psi tyre pressure. Wonder how quick it would be with 34psi boost and jungle juice.
Ummm, from my current calculations, he'd run 137MPH. Or thereabouts :(
Stupid geek hats!!! Need new batteries :headspin:
Mmmmm, booooosht!
Man are my ears burning!!... :)
The thing only ran 11.01 or .02 at 136/7. that night.........It was in full street/circuit trim, 60 foot was pox on cold RE55's.....but the worst part was sittin around for and hour in between passes :D ....I'd rather blaze around lap after lap....
I'll leave the drag(brag) racing to you guys.....lol
You only like going round lap after lap coz you do twice as many laps as anyone else in the same amount of time :)
LOL...Ash has taken over the talking it up role on behalf the RWD crew:)
You coming to Sandown weak sauce?
I would highly doubt the brakes will get done by then... wait till you see what im putting on there Troy... you're gonna get excited f0 sure :D
I sure am.
Man are my ears burning!!... :D
If i issue a challenge to you would you come out?
I've done it too funboy - no show
Snowman - all i hear is excuses
I fully expect to get flogged of course, but one can dream :wassup:
I sure am.
Tell me everything:) Im still in 6 minds of what to do for brakes., if i need them at all as the only place i seem to have trouble is Sandown...everywhere else they are fine:(
Had a moment last night with the NSW Constabulary...so who knows how long its going to take me to pay off the fines and get the car back on the road:(
LOL...$78 fine for having last years rego sticker displayed...lol thats it, i love being me:)
Hey Emre, how is the car now, and the family for that matter?  All good? My mate Steve is moving to Sydney to a new job. Get's Leanne closer to family but he still loves his job and Traralgon.
All good mate, should come up for a BBQ again and catch up. :)
Loves Traralgon you say... Well , some people love the looks of the AU Falcon, so I won;t question it. :P
I would highly doubt the brakes will get done by then... wait till you see what im putting on there Troy... you're gonna get excited f0 sure :P
I sure am.
Stop going on about brakes and suspension, u said the same thing when i asked you why you werent racing at wrx phillip island day.
My brakes are shagged at the moment and need some new rotors, but i will still be still trying my best to go through turn 1 at sandown without bouncing off the curves!!!
i no shit will let you drive my car so you understand how bad it is ;)
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
