  • Replies 59
I didnt receive the pumps on friday but I have been tracking them online and am expecting them this monday. I will let you guys know as soon as I have them.
Heres a link to a usefull install guide - click here
( its for a 984 but is a very good reference if installing an 040)
u dont realy need instructions. positive and negative, use the original mount so that the pick up is aprox 15mm from the bottom of the tank. thats it.
is there any chance of another group buy in the next month???
cheers
Ur right - they are a simple install.
Note - the 040 dont have a sock on the bottom and they sit a bit higher than 15mm from the bottom of the tank.
Might organise another group buy if there is enough interest.
Prices may vary slightly due to exchange rates etc...
aargh!! I am so pissed off!!
The pumps still havent been delivered to me.
I am tracking them and they are held up cos of the shipping company??
I will call them in the morning and get to the bottom of this.
I dont think they will be arriving by this weekend though.
Sorry for letting you all down. Im not at all happy bout this :)
got mine too 2.30pm. thanks paul. just having a few probs installing it lol.. but yeah
http://www.silviaspares.com.au/tech/fuelpu...ll/pumpinst.htm
that shud solve problems if anyone needs it.. i jus gta reconnect the wires to the pump. but i got no solder lol.. or bolts :)
any one get there's? i didnt :)
Hmm.. I was afraid that might happen.
The guys in NSW and VIC wouldve got theres yesterday but the guys in WA and SA will definitely get there pumps on Monday.
Although they where sent by express (gauranteed next day delivery) there is still no assurance that they will arrive the next day.
This gaurantee is only if you live in major cities and are sending to major cities.
uinfortunately I dont live in any major cities and this has probably caused the delay.
I hope this delay hasnt put anyone out.
Hey Guys. I am glad that you allreceived your pumps ok.
If anyone else is after a fuel pump for a great price then I have another group buy going.
click here for details
:P
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
