Those of you who have missed out on the silver kits on my last group buy then join this one.
Hi Guys
price. May come down if I can bargin with my manufacturer.
$450 delivered without cooler if you make a deposit. + $10 for WA and TAS.
$700 with cooler delivered if you make a deposit. +10 for WA and TAS
These coolers are quality copies and come which a 1 year warranty. I have sampled many coolers from different manufactures from China and Hong Kong and these are the best coolers I have come across. They have solid welds polished finish and made from quality alloys. If interested in a specific cooler size. I might be able to get it for you through this group buy. Ask me!
If you want a different cooler than the 600 x 300 x 76 let me know and I can order one in ther are 10 different types.
Deposit
deposit without cooler will be half. so thats $225 or $350. Payable upon enough interests..
List of available kits
1. SKYLINE R32 2.0L GTS-T It is R33 kit with different silicon joiner.
2. SKYLINE R33 2.5L GTS-T
3. SKYLINE R34 2.5L GTT
4. 200SX S14
5. 200SX S15
6. SILVIA S13 2.0L
7. 180SX 2.0L
8. 95-00 IMPREZA GC8 WRX & STi - no available
9. PULSAR N14 GTiR
10.LANCER Evo 4, 5, 6 & 6.5.
Specs
Kits
High quality hybrid style kits. These kits are no cheap copy. They have been made from aluminum using a mandrel bending tothe same specification as the hydrid kits.
2.5" piping mandrel bent
made form aluminum to minamise heat soak.
Hybrid style
Intercooler
Hybrid style cooler.
Attrictive polished aluminum look
3" inlet and 3" outlet pipes for high flow
Low pressure drop 0.2psi at 15psi of boost
80 psi for up to 800 horses
Made by lightweight but strong material. Same Structure and material used as famous "Hibrid" Intercooler. Weight ~8kg
All coolers have been Pressure tested.
15 bars core design. For more efficient air flow over the older 16 bar design.
Delivery Time
As with the coolers it took about 20 days to arrive in brisbane and another 10 to get to your door. So about a month in total.
Registered Postage (must sign for parcel and online tracking)
Once posted you will recieve a tracking number so you know where your parcel is.
Payment
As soon as I can get 5 or more people.
Warranty
There is a 1 year manufacture's warranty.
msn contact: [email protected].. I will have it on after work
Photos are of the blue kits I have in stock
https://www.sau.com.au/forums/topic/75026-silver-intercooler-kit-group-buy-2/
  • 3 weeks later...
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
