PRICE DROP NOW with ADAPTER $100...
PRICE
BOV with universal Adaptor is $100 if I dont have the pay customs. If so , then add 20% ($20) + 15 postage... I will be getting these guys flown over takes under a week to get to my place :(
DETAILS
I have finally added it to my car and it sounds great :) .. It sound just like the wav files a few replies down.. ON low boost it flutters a little but 5 pound+ its loud and furious...
There is a screw in the back which adjusts the blow off rate. I found adjusting the screw all the way in gave it a really tight sound, all the way out was a loose sound. (psh compared to ppsssshhh) just like the wav file below..
SPECS
The BOV is made from billet polished aluminum.
The HKS Super Sequential Blowoff Valve (SSQV) is a dual stage pull type relief valve. Unlike other blow off valves that are push type, the SSQV will not leak under high boost conditions nor under vacuum at idle. Being of a pull type valve structure, the SSQV can not physically leak under any level of boost because boost pressure also keeps the valve closed against its seat. The SSQV is actuated by pressure alterations only, not by the rate of pressure or vacuum in the line, which ensures a quick valve response and complete closure during idle. On typical blow-off valve designs, a large valve is utilized in order to accommodate high boost / high horsepower applications. However, these large valves tend to react slowly and require high activation pressure to open, therefore are not able to activate and prevent compressor surge at light-load conditions.
PEOPLE WHO WANT THE BOV
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
SHIP DATE
As early as possible. I'm aiming at 2 weeks before I ship or 10 takers which ever comes first.
PICTURES
I will add some picture of it in my car... Not that I want to because it is the first time I have welded in 6 years. you will see why..
https://www.sau.com.au/forums/topic/75282-hks-style-bov/
$50 for postage?! That's abit extreme isn't it? Well, how do these imitations compare with the real HKS ones?
LOL exactly right man.... there is a dodgey prick on EBAY selling fake HKS SSQ for prices cheap as chips... monza bovs made to look like hks.... sorry but lots of people are weary now..
id buy one but only if i could inspect in person as ive had HORRIBLE luck with this... see my previous threads about ebay and hks ssq...................
if its genuine, you should have no trouble selling them to people so try buy them imo and sell for a profit of 200 to friends :(
https://www.sau.com.au/forums/topic/75282-hks-style-bov/#findComment-1381687
I just read some of it. We will see after I install it on my R33 and see how we go from there. If sounds like I think it does I will be very happy and the GB will prevail. Otherwise I will cancel it. But for the now the sample I have looks really nice and everything seems in working order. :(
https://www.sau.com.au/forums/topic/75282-hks-style-bov/#findComment-1381768
i got one of these BOV. They are good! I had no probs with them.
You dont need adapter..just need hose & the flange so u can place the BOV on top.
I was actually selling one here in SAU before but no one wants it, although offers are made & but buyer fell though so i sold it in ebay with ease :uh-huh:
Heres what it looks like installed in my engine.
http://www.geocities.com/j_aaron71/closerbov.jpeg
Linky to the sale i made.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...AMESO%3AIT&rd=1
https://www.sau.com.au/forums/topic/75282-hks-style-bov/#findComment-1395442
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
