Best to do a search, but you'll find GT2540s are a little mistmatched for a stock(ish) motor, better off with GT2530s, GT-SS generally.
get 2530's .. i have a complete DVD all about the mines r34 GTR> goes for around 1 hour.
that thing is so nuts.. you guys havnt seen all of its glory YET!
2530's!!x2
On the GT2540, the decision you have is what power do you want and what is your use - street, track or drag...?
I have 2x GT2540 and had HP drop off at 7000 rpm. I use it for street / track. Pressure management showed that the 3.5" Blitz turbo back exhaust was restricted at the cat and muffler. The turbos are at full boost by 4250 rpm. But...I have full forged internals.
Stock internals, I agree with Morgs. Stock you can push 330 wKW with a pair of GT2530s. But you cannot run this power reliably for track use - you will run lean in cylinder 6 and even with a power FC you will get pre-det once the engine bay, induction and track temperature rises.
If you plan for forged internals, increase intercooler and radiator size and add an oil cooler I would go GT2540s. You will run max HP spread from 5500 - 8500 with a 4" turbo back exhaust.
HL
thanks for your reply guys. i hav stock internals and only plan for street use (weekends mainly) one guy told me the 2540's were quite laggy compared to 2530's which makes street driving terrible.
and that stock internals may not handle the full force of 2540's??
im getting my car dyno'd with
pod filter
exhaust (twin 2 1/2" all the way)
apexi cooler
pfc
for now hoping around 220awkw
my goal eventually be around 300-330 with the turbos, injectors,fuel pump.
HL
Full boost by 4250 rpm with 2540's???? Have you got a dyno graph to prove this?? Yet later in the post you say you get max HP spread from 5500 - 8500rpm??? I'm confused...
Also forged internals will not help you with response, its just stronger!!!
From talking to hundreds of people, 2540's are very laggy on a 2.6, and the response could well be non existant!!!!
If anything wouldnt forged internals decrease response? Due to making the rotating assembly heavier?
I don't know about yours, but my forged internals are much lighter than the cast ones I replaced.:P
so in theory lets say drag wouldnt the 2540's be a better choice because of the hi-rev launch?
Still dop off boost on the upchanges. It's all about the average power available/used on the run. The max power at one rpm point is irrelevant.:P
well the main reason im asking is that my engine is getting rebuilt and i hav a pair of 2540's doing nothing at the moment. At the moment i really cant afford the 2530's so i figure the 2540's will be much better than the stock gtr turbo's? correct me if im wrong.
What are you getting done to the engine? A bit of extra capacity will help the poor old 2540's. As would some more compression, a set of mild cams, gapless rings, ceramic coating the combustion chambers, exhaust ports and the piston crowns. Maybe power port the exhaust manifolds and a set of split dumps are a must (not those short ones, the combined dump and engine pipe style). Basically anything that makes more exhaust flow:cheers:
when i got the car dyno'd i realised the rings were shot. couldn get much rwkw out of the little sucker. so to cut a long story short i need to rebuild the beast. forgies i reckon will be on the list!! make use of the 2540's no cash after the rebuild to get any thing else. perhaps raising the revs to 8500rpm should help them flow better.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
