Hi all,
Tomorrow I'm getting a 3" turbo back exhaust system from Exotic Exhaust. My current system is stock and the new system will be a 3" split dump system (mild steel) with a stainless steel cannon tip.
I thought I'd share the differences it makes (sound wise):
Stock - Startup
Stock - Light Revving
Stock - Close to exhaust
Tomorrow I will post the 'after' sounds.
https://www.sau.com.au/forums/topic/75621-r34-gtt-before-after-exhaust/
You'll notice a definite difference in power and in cabin noise. You can sort of hear it chuffing away when you get some revs on and it is generally louder inside the car but you get used to it.
Having a split dump is good for top end power. You will notice how much freeer the engine feels above 6k rpm.
Now, for the after sounds:
Modded - Startup
Modded - Light Revving
Modded - Close to exhaust
I'll post pics a bit later but if u can imagine a split dump pipe that joins after about 20cm then 3" mandrel bent mild steel through a hi-flow cat and into a huge cannon muffler (I didnt think it would be this big but it is).
I may change the cannon to something less conspicuous.
Splits make it sound angry don't they... where is Exotic Exhaust located and how much did u pay (pm if you wish). I'm hunting for a zorst in Brisbane also for GTT. Tossing between $2k for a CES system or other options. How droney is it in cabin if u get up it (h8 droney!)?
Exotic Exhaust is located in Sumner Park (Jijaws St). The service is pretty good and I spent $1250 all up. It took them about 5 hours but they were busy and I got squeezed in. If u want to meet up at some stage to have a listen, PM me or u can pretty much get me on MSN ([email protected]).
The car is quite loud/drowney in the cabin but apparently I'll get used to it (haven't driven it around much). There is a quiet spot between about 1800 and 2200rpm and then it gets loud and it goes quiet again after about 4500rpm. The performance difference is noticable though. At some stage tomorrow, I'll get pics of the dump and piping (u can see the top part in the engine bay).
Apparently the cannons are louder than say a SS twin tip, so that might help reduce the drone. Another option I'm thinking about is BATMBLS splits and hi flow cat with a Fujitsubo or similar cat back (bottom one in pic) can't see if thats got twin tips and not sure how droney vs restrictive that would be. Would work out about $1400 + labour, unless I can find a cheaper GQ Jap cat back.ex011.jpg
Well I should now mention that I got defected at the BP Yatala Super Servo on the way to BWCP. 98dB - the limit is 90dB. The car has a cat and a cannon so I guess I will need a resonator/muffler to quieten it down. Good news was that I didn't get a fine because the officer knew it was a brand new exhaust.
I also have to secure my air filter.
Yeah, thanks guys. The sound is awesome but I have been told by a few people that a silencer may not do the 8 or 9 decibels. In terms of the testing equipment, they use a microphone and a tripod and get u to rev. At idle, I was at 88dB and at 75% load (where they test it), it was 98dB. The testing method they show at this site is what they did: http://www.airpowersystems.com.au/us_spec/...swrx-hoe-r2.htm
I noticed in that testing procedure that there needs to be at least 3 meters of open space between any side (front, rear and both sides) of the vehicle and other objects. This is probably so that the sound meter doesnt pick up reverbing noise.
If a car (including the cops) is parked next to your car in the spot where they test your vehicle, take a photo of the test being conducted with a date stamp on the camera and your license plate as well and dispute the defect.
Makes me wonder how many times they actually follow the procedure correctly.....?
For example the standard for testing exhaust noise states: "Engine RPM must be held steady at 75% of rated peak horsepower RPM"
Wonder how many cops know the actual 'rated peak power rpm' of all the different import RB engine versions? Or do they just look at your redline and tell you to take it to 75% of that. I'm sure thats how they would actually do it.
An R34 GTT for example makes Max Power of 206kw @ 6,400 rpm 75% of which would mean that they should of tested it at no more than 4,800 rpm
If they don't know exactly when peak power is made they are likely to base it off the redline which is closer to 6,600-6,700 rpm . So at 75% thay might be ask you to rev it too just over 5,000 rpm.
Its all a matter of inches when your talking after market exhausts and db, just something everyone might want to remind the cops of when they are db testing your vehicle!
Yeah they did have the cop car parked along the left side but in front of the car. The walls of the carpark though may have contributed to resonance. The test area was the caravan section of BP Yatala and the closest wall was about 4m away. The 75% load was 4800rpm. The officer had a chart of engines and RPM's but based it on the R33 RB25DET so I guess mine should have been different. Tomorrow the muffler and resonator etc get installed and tested. I hope it doesn't drain too much of the performance...
I will post after after sounds....
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
