Hi everyone :wavey: ,
I am thinking of buying an R32 GTS-t and was just wondering how good the RB20 is. Would it be better to swap it for an RB25 or even an RB26? Since I will be limited by price I would probably be keeping the RB20 in there anyway.
Also do they responed good to modification? I heard that they are stronger than an SR20, an can take more punishment.
Would you say that the GTS-t with the rb20 would be a good place to start, since it will be my first car?
https://www.sau.com.au/forums/topic/75875-rb20-how-good-are-they/
So I'm guessing by what your saying that it would be your first car? I wouldn't reccommend a turbo charged skyline as your first car if your getting your license cause you will more than likely smash it up anyway and cost yourself more money than its worth. Buy a banger for a year, learn to drive and spend the time looking for a decent R32 in a year time. Only reason is that I'm hearing too many stories these days of P plate drivers hoping into powerful cars and blowing all there money from one swift slide into a lighpole (or evening injuring themselves seriously or ending up dead).
Now back to your first question. RB20's are solid motors and underestimated by many but have there limitations. Commit to a RB25/RB26 only if your planning on pumping tons of money into it. Best way to modify a RB20 IMO is to buy mods which would be compatible with a new motor if you decided to buy one especially considering a lot of parts on the RB20 are interchangable with the RB25. I still think RB26's are a bit heactic to be putting in RWD cars so better off saving the time and getting a GTR if thats the case.
its a good idea to get something that you can actually LEARN to drive in. and by that i mean without your mum or dad sitting there telling you how to drive because seriously,almost everyone drives very differently after getting off L's. even if you bought a turbo'd skyline but kept the wastegate open for 6 months or something so that it wont boost. its actually a very smart way to do it IMO. and can save alot of $$$$$ in the end. think about it dood.
I've been on my P's for a while now......., what I ment was to "practise" driving. I was gona get a GTR but I thought that would be too powerful for me so I decided to get a GTS-t.
mate you'll be right with it for your first car. Standard aint that quick anyway and it will take a good couple of years to build the hp anyhow. But the RB20 aint as quick as a RB25 only due the the RB25 running more compression , but that also means its a lot easier to **** out a RB25 by flogging the shit out of it rather than a RB20. Both motors are great. Its really a win win power/life which one you prefer. Good luck
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
