G'day! With a trackday looming FAST (this coming Monday the 13th),I really need some sticky rubber. I'm really not up for a brand new set (somewhere between $1K and $2K for reasonable stuff..),so was wondering if anyone had some slightly/mildly used tyres that they would depart with for reasonable $$$'s? I'd need either 245/45/17 or 235/45/17's in something STICKY and road legal,as it's about to be double points and all that associated glaring attention it brings,especially aroung the Police State that is Goulburn. Obviously,I'll need 'em before Friday so I can get 'em fitted and balanced before promtly tearing 'em to shreds on Monday,hence the call-out for help! Normally I'd post this in the "wanted to buy" section,but as time is running out,and the tyres must be had locally...Anyone? Pleeeeaaase?!?
https://www.sau.com.au/forums/topic/76016-urgently-reqd-sticky-rubber/
  • Replies 52
hahah no tyres for you! you don't need the help. See you on Monday and good luck finding some rubber.....you really should buy some proper ones like re55s, they will last a few days and are great to drive on.
Let me know if you want me to pick up something in Syd and bring them down, I will be in Goulburn from Sun night
Ah,it's all good! If I can't find something,my new Pirelli P Zero's will just have to take a beating...LOL! Being that the Dutton Rally is over,here's hoping... I will get around to some new tyres;more likely when I get a second set of rims...
Got a set of some Ed special dodgy Maxxis pieces of crap... not much good for actual track use besides belting the car sideways every opportunity you get :O Just thought id offer :P
Will be coming down to check out track day, but that stupid firewood log has left me pretty damn broke, so no entry for me (ill get there one day!!) :)
I dont know if this is what your after, but i have some falken rubber, cant remember the series but theyre 235/40/R17 and 255/45/R17... theyre off my old work rims which i stuffed..
Let me know if ur interested
he would need the same rubber all round dayne eg 4 x 235/45/17 or 4 x 255/45/17
but i am sure he appreciates the offer :P
Jayce,
Apparantly Tempe have Falken RS-V04 semi slicks in stock in various sizes, 255/40/17's being ~$240 a tyre. This is only hearsay, give them a call and find out, could have them shipped overnight, and fitted tomorrow if you were real keen :P
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
