im looking for the best places to pickup a R34 GT-T...
after fuel consumption, etc with my 200rwkW R33 GTS-T, im chasing a little more cheaper to run, nicer looking, etc car, thats a bit more 'sensible' power wise aswell.
basically its as follows..
R34 GT-T 2 door
manual pref. but tiptronic is an option
black
R34 factory sports kit would be nice, or any kit for that matter, but stock is fine.
sunroof (pref.)
exhaust (pref.)
got ~$30,000 to throw around, but obviously the less, the better.
and if anyone is chasing a 200rwkW, white kitted R33 GTS-T, gimme a yell!
cheers :O
https://www.sau.com.au/forums/topic/76056-buying-a-r34-gt-t/
Mitchy
If you want to change to an R34 based on fuel economy..don't.
Fuel economy of 33 and 34 would be almost identical.
Fuel economy is more related to the ol' right hoof whether it be modified or not.
My REX is putting out maybe 40kW more than stock and gets 10l/100kms normally.
Who said 34's are nicer looking :)
I've had both and a nice 33 will grab my attention in traffic moreso than a 34 but that's just my preference.
If your chosing an auto then the 34's are much nicer with the tiptronic function compared with a 33.
At 18 I'd hate to be paying your insurance costs
a stock R34 is going to have better fuel economy, and lower insurance costs than my 200rwkW, 5km/L R33, surely :P
If your car is tuned correctly and you drive the cars in a similar way fuel economy would not differ greatly.
If you are having a problem with excessive fuel consumption and the car is tuned right as I said the biggest factor is you.
Cheers
Except you Mr Traitor!
Yep sorry
The REX was the wifes choice (been my choice all other times)and I think it's been a great little car. I do miss 6 cylinders though.
Once I replaced the Bugeye headlights it didn't look too bad.
My Missus didn't like the 34 and wouldn't drive it because she couldn't see out the back >
I actually think the 33 is a sweeter looking car but what would I know I'm waiting for a CPV35 :P
Cheers
ok, ill straighten out my story..
i enjoy my R33, but in a modded state, it chews more fuel than i would like, seeing as its my daily driver.
my reasons for wanting a (stock-ish) R34 is, 1) fuel economy, 2) lower insurance, 3) it looks much nicer, 4) not as common as a R33, 5) newer car, so hopefully more reliable, etc, etc... i basically just want a R34 :D
You won't get cheaper insurance, because the value would be insured for a lot more than you're 33. If you are going to spend more money on a car spend it on what you have now!! (unless something is wrong with it)
i got quotes for both my current car, and a R34..
for me to have the R33(valued at 20,000) its $3,000
for me to have the R34(valued at 30,000) its $2,400
the R33 has a fair few 'performance, and handling mods' they up the insurance because i have bigger brakes, etc... stopping quicker is bad!
Damn, insurance companies are f***ed up!!! I can't see why it would happen like that, but oh well, if you want a 34 go for it then! I am guessing you aren't planning to mod it then, otherwise you would be going against you're reasons for getting one.
thats true with regards to insurance my R33 cost 1850 a year to insure for $20k and now i have the 34 it costs just over $1400 insured for $33k??? work that out? maybe the R33 has a bad history with insurance companys so they put it in a higher risk category and cause there arent as many R34's (yet) they are not classed as risky, just a guess here, someone correct me if im wrong.
but with regards to fuel economy there aint really much difference between the 33 and the 34 i think, even though my 34 has a bit more power than my 33 had, it does use quite a bit more fuel for the small amount of power gained.
my 2c :):D
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
