Complete kit, consisting of:
HKS highmount manifolds
Twin HKS wastegates
Two Garrett 3037S spec turbos - HKS 0.73 A/R rear housings
Exhaust pipes to cat
Piping from turbo to intercooler
Was planning to use this *when* my motor was built, but due to unforeseen circumstances this is being abandoned. Everything is in perfect condition, turbos are brand new still in their boxes. Was bought as a HKS 2835R kit and upgraded the turbos on it. Still have the 2835R's if interested in them.
$8500 ono
Also 4 layer Trust intercooler, 600x300x135mm will sell with the turbo kit for $1500
Tons of other parts, 280 + 290 cams, 1000cc injectors, Cusco front diff, etc etc. that would suit such a buildup.
Edit: 29/8 - parts are all sold!
https://www.sau.com.au/forums/topic/76226-hksgarrett-twin-3037s-spec-kit-rb26/
They are packaged in Blitz boxes, made by Denso (as they all seem to be). $1000 for the injectors.
Edit: Just took one out of it's box for photo - the others have never been opened.
Injectors are sold. Asking $2,000 for the intercooler seperate from the turbo kit. Located in Sydney. Workshop was closed over long weekend, so was unable to do much about it.
JUN plenum might be available in the near future, the person who has it is reconsidering the direction their project is headed. Will post up if it's for sale, but until then not much I can do :D
god ****ing damn if only i had 8000 spare i'd offer that for the complete twin kit
but well yer just spent about that much of a 26 for the silvia : they'd be insane in a little silvia ;)
good luck to who ever buy's this insane turbo setup
  • 3 weeks later...
  • 3 weeks later...
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
