  • Replies 43
Check the air reg down where the injectors are.That may be dirty inside aswell.There is 2 10mm bolts holding it down and 2 fat hose's each side.
__________________
is it square shaped type off thing?
can anyone think off a reason why it will idle high when AAC valve conected
but idles normally when its not???
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1408971
It still idles high even when I disconnect it... I admit it does drop, but not a lot and it still idles way too high and now this hunting thing is driving me mad, I will sit at the lights and it will bounce between 1000 and 2000, bloody irritating!!
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1409000
Okay, I disassembled and reassembled my AAC valve, didnt do anything, Im in the process of putting the Air regulator back in, just waiting for gasket goop to dry. I think this might do the trick as the spring wasnt under any tension which would suggest that the plate couldnt move due to being in the incorrect position. I will post later to confirm If it worked
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1409955
Well the Air regulator is back in and the car idles around 1000 and stays there, no more hunting for me!! I gotta say it was pretty easy and you can't really go wrong with the internals of the regulator, they only go in one way.. I'm happy with the result.
eXc your guide was how I started out repairing the valve, great one mate. Cheers
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1410308
i sorted out most of my prob
found that the turbo smart blow off valve is most likely after i dissconnected it i had allmost no drop in idle at all and never stalled
connected it and again after pulling up at light ect.. it would stall and drop really low idle
i opened the bonnet and reved the car and watched the BOV found that it was sucking in air because the valve would not fully shut
so now its disconnected
maybe the rest of the prob is the fuel pump
as silvia pumps operate with a ground swith that at idle it drops the current to the pump so low that it cant operate properly (i have GTR pump)
so on the weekend ill find the earth wire from the pump and run my own bigger gauge earth to a earth point in the boot
hopefully it fixes the prob or ill have to run a new cable from the switch and new relay also with same gauge wire
hope it works
cheers
matt
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1412432
timmy c
The air regulator has two bolts holding it to the intake manifiold, get those out and two hoses and connector and your on your way, you can take more hoses off to give yourself more working space as well. eXc's tutorial is good try use that, getting it out was the hardest part. It will require a little patience, but will come out. The screws on the air regulator are tough ones, but I sprayed them with a bit of lubricant and used a quality phillips screwdriver head and just moved it a little at a time, also helps if you push down on the screw to stop it stripping the head, I thought they wouldnt come out, but with a bit of patience(again) they came. If you got anymore questions post away
Good luck mate.
blackrb20silvia let us know how the pump goes
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1412973
Hey guys,
Took my regulator apart today. Is the spring supposed to hold the rotating thing shut entirely? Mine is half open? It wasn't dirty at all either so maybe its the AAC instead....
I put it all back together and now the idle is high :D its idling at around 1500. Before it was fine, I don't think i've changed anything. Its shit!
Anyone got any ideas?
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1415867
I played with the water temp correction(wrote down what setting it had first so I could set it back if need be) table and thats why it revs high when cold.I got it idleing at 1000rpm when stone cold but it was rough.
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1416251
Yeah I fixed the problem, I put in a stronger spring then factory. It idles up fine but now when warm it drops straight down no messing about. :(
It still hasn't fixed my start up issue though. When I start the car in the morning I have to give it some throttle or it sits around 200RPM and coughs and dies.
The guide is good but the pics don't works anymore.!
https://www.sau.com.au/forums/topic/76317-aac-valve/page/2/#findComment-1417068
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
