Hi, (done a quick search, didn't find much info)
I just got new 235/45/17 tyres and measured the psi and i thought it was high, i rang the guy where i bought the tyres and he said to keep the tyres at about 44psi.
What psi do you guys use for daily driving and what do you think of 44psi?
With the previous tyres ran between 36 -38psi.
so what psi should i run ?
https://www.sau.com.au/forums/topic/76321-44psi-daily-drive/
Having them on a high psi is good for wet weather (helps force water out the sides)
having them on a bit lower psi will get a bit more rubber on the ground.
Then again first P.I track day i went to, they recommended if your running street rubber (not stickies) to run 5psi above what tyre rating is... so around 40-45psi on mine.... so who knows.
What do you mean by cold? and Hot?
air is denser when cold, and expands when hot
so a pressure of 30 when cold and 35 when hot would be about the same
personally i keep my tyres at 32psi (when cold)... why 32? well my mate's dad owns a tyre shop and that's what he recommends for even wear over the tyre thus maximum tyre life :D
Warren.
40 psi hot, as recommended by the instructor when i went to the Driver Dynamics advanced driving course here in Vic. Improved wet weather handling, tyre wear and feel of the road etc, with a slight loss is grip. If i wanted max grip, id run much less pressure, but the handling would be shit. IMHO
How long have you had them on for? If you literally just got them, you need to run a higher pressure to bead them in. I'd probably leave it for a little while before changing the pressures.
As for what pressure you should run day to day, what kind of tyre are you using? It can make a difference.
However, 44psi sounds way too high, especially for a 45 profile tyre.
Aside from the water evacuation reason given above, there are only 2 other reasons I'm aware of to run high pressure. If you're doing a fair amount of highway cruising, then you want to run them high to lower the rolling resistance (which improves economy and tyre life as there's less friction). The other is to use air pressure to stop the tyre sidewalls from flexing. Obviously with a bigger profile you'll get more potential flex, so you need to run higher pressures to offset this.
However, aside from decreasing your tyre contact patch there's also the issue that the tyres are more likely to overheat. This means you'll get more squirm from the tread block, and drastically reduce tyre life. But, you'll need a sustained load on the tyres to generate enough heat for this to be an issue. I'd hazard to say that, even for most street cruises, a sensible driver will never get their tyres hot enough for it to be an issue.
For day to day driving, if you're on a nice set of street tyres with a reinforced sidewall (or a set of Formula R semi's), run a lower pressure. You'll get more grip and more resistance to overheating, and you let the tyre construction avoid sidewall flex. If your sidewalls are soft, then run slightly more to improve turn-in.
So how much you run is a balance of these factors, which is obviously going to depend on your car and your tyres. Its not possible for anyone to give you an exact number unless they've been in your car. In the end, someone has to do "tyre tuning" to get the pressures right for your rubber and your car. We can only tell you what effect changes will have.
Just got them(done about 250Km) they are
Hankook K104 235/45ZR17 94Y(300km rated) XL(xtra loaded)
just dropped the pressure to 38psi
they are on a r33 with 2 degree camber at the front and about 1 degree at the back.
Will trial this psi for a while. Heard that the tyres take about 500km before they realy start to stick.
how big are the rims??
i have stretched 235s over a 9" rim, and i run 45psi. feels nice and tight. bit rough, but so are the coilovers, all depends on what you feel comfortable with and what your tyre wear/depth of wallet is.
i used to have 255s, which were a bit big for the rim, handling has improved immensly with the 235s....i pumped the 255s up to 55psi for a quick run and they still didnt feel solid.
cheers
Linton
When I googled for your tyre, the first hit was 101tires.com's user reviews. Most of them complain that the tyres have shithouse sidewalls, so maybe you will need to run the pressures high.
As an amusing aside, you'll notice that all the reviews by Yank Tank owners (Lincolns, Mustangs, and other cars not exactly reknown for their handling) think they're a reasonable tyre, whereas the people that are putting them onto Euro or Jap cars think they could have defecated on the rim and come up with a better tyre. :(
Not sure how long it'll take your tyres to run in. However, they won't grip very well for the first couple of hundred kilometres. They use some lubricant during construction to make it easier to remove the tyre from the mould, and then when they spray everything with tyre black (to give it that lovely sheen that all new tyres are blessed with) that doesn't help with grip either.
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
