ADR69 (full frontal impact occupancy protection) does not apply to any vehicle prior to 1995, however, all aftermarket panels must also be certified and have passed crash testing.
So basically no, the bonnets are not legal unless they have undergone crash testing and have been certified by QT.
  • Replies 46
Posted Images
Hey all this is my 1st post. ah was going to say the same thing as above. The people who imported my car said something along the lines of if its befor 1995 than it can be legal but has to be certified anything over 1995 than apparently not at all.
  • 5 weeks later...
At the MSC I was showing the couple in the burgundy R33 my FMIC isnstall and a guy from TTR (??) racing said that he could clear my bonnet of a defect becuse it is a fibreglass bonnet with a carbon covering, anyone gotten off a defect like this?
let me firstly say hello to everyone i'm new to this site I've just purchased my first skyline I imported a 96 R33 GTR Vspec through SVi they made the process so easy for me and i would recomend them to everyone i'll post some pics up for everyone after i get them. I work at Custom Carbon and let me say that this is a huge grey area at the moment and it really comes down to the individual officer,we are still having tensile and compression test on a few of our bonnets for the ADR approval. The funniest thing is still to come thanks to project A380 there is now a world shortage of 3k carbon so with this in mind we are experimenting with a new carbon twill,cant give too much away but i hope to have a few products on show on my GTR at an upcoming show. If anyone has any questions or any quiries just pm me or contact Custom Carbon on 07 38652014 hope to meet up with alot of you in the future.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
