heys
being a noobie to this whole track thing, was wandering how do u get ur car on a track and how much would it cost.
short of making the two hour drive down to collie for their "drift days" to get some track time and try drift, is there any tracks close to perth, that are relatively cheap and allow for drifting or grip sessions?
only tracks i noe of are ahg, mc, wanneroo and kwinana plex. basically would like info on how to get car on track and for how much.
cheers
https://www.sau.com.au/forums/topic/76733-track-work/
SAUWA has an MC team going in for the Winter Series, PM Sneeza if your interested.
We also will be holding another driver training session at AHG in the next couple months.
Other than that, I'd join the WASCC and do track days at Waneroo once a month.
Cheers
Paul
https://www.sau.com.au/forums/topic/76733-track-work/#findComment-1405607
perth performance car club is another good club for some motorsport. ppcc hold regular events that have so far been at the AHG centre doing skid pan and the track. most of us are starting out so the idea is to try a club day at collie and wanneroo etc as we get the numbers.
we have a wet skidpan day coming up at AHG. if you are keen send me a pm and see if we can secure a spot for you. the more motorsport oriented members we get the more motorsport we can do :D
edit: the website is www.perthperformance.com, check out the forums.
https://www.sau.com.au/forums/topic/76733-track-work/#findComment-1405784
all fours and rotaries also run track days, www.allfours.org.au
they have a track day at collie comming up, which has been delayed to august due to the track rebuild down there, they have run waneroo days in the past, but the cost of hiring waneroo 3kish is somewhat preventative to running them now..
joining the WASCC is another way, membership is about $215 according to the website, and renewual is about $180, this allows you to hit the track on tuning days for $40 odd, saddly they arn't very drift friendly, and you'll get a talking to if you try..
your also meant to only go at 80% of your capabilities, no on ever does but they say to only go that hard..
collie is your best bet, just saddly atm, as it has been since the start of the year, they are doing some big upgrades down there, which have been delayed due to weahter and other issues, which sucks, as it'll have been nearly 9 months since legal drifto by the timewe get there in august..
https://www.sau.com.au/forums/topic/76733-track-work/#findComment-1406189
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
