CC - mate i got same prob.......the seat belts wont retract properly........if u find out a good fix can u let me know! I'll have a hunt around myself...maybe its just the retractor thingy (my technical term :D ) has given up the ghost!
Mate just go the 5 point harness..... u got the seat for it lol
Ando
yeah my front seat belts also don't seem to wanna retract properly at times, althoug with a quick jab they normally work again, i'll prob get some new ones soon, thou also wanna know which ones fit, so can we confirm that only s13 ones fit, or also r32 ones?
R33 deviat have you tried giving the seatbelts a gentle yank? it's the way japanese seatbelt work, they are electronic, if you give them a ever so gentle tug they usually retract themselves,
same goes for you CC
try pressing the release button if it just happens occasionaly,
i was trying for 5 minutes to get the passenger seatbelt to retract once, then just pressed the button and it zoomed up, felt a bit stupid after that,
i dunno how it worked or if it was just coincidence?
electronic??
Cover the seat belt in silicon grease. You can usually buy these in spray cans from supercheap. Once it is covered in it wipe it off and presto it should work better. May need to repeat a couple of times to get it right but it should eventually retract like new. Also something else to note, silicon grease is good for windows that are a bitch to retract, simply spray it in the slides and wind it up and down until it starts to get better.
Mr Eps.....yeah man i do give em a yank, which works, but it just feels a little unsafe when ur driving and it isnt 'tight' around ur chest....doesnt take up the slack..... will try a few things mentioned here, see how it goes!
so you cover the whole seat belt from start to finish with this silicon grease?
i'm not totally sure how this will work but i'm guessing it would just make the belt slide through the loops easier with less friction, is that right? i thought it was the actual retracting mechanism that would be playing up...hmm...
Thanks for all the suggestions guys... I'd try that silicone grease stuff but my seatbelts don't wind cos they're old and my windows don't go up cos they fall forward, I think it'd be a bit hopeful in my case.
R32 fit?
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
