I'm 16 and have always been a skyline enthusiast.
i had been telling my dad that the skyline is the car for me, but he did not approve because they come stock turbo. :werd:
Recently my dad's freind knew of this guy that imports cars from japan to Australia and recently brought one in.
For a price of 14,000 my dad and i went to check it out.
when we got there we popd the hood then had a look at the registration.
it said " Nissan Skyline r33.:"
it is not turbo and i cannot find if its a gts, or whatever. all it has is a gt at the sides and an "s" at the front.
its a twin cam 24 valve non turbo skyline.
to me, ive never heard of just a Nissan skyline r33.
its a 1995 model.
ive never heard of just a nissan skyline r33 gt
please give your thourghts on what it is? :confused:
it may not have turbo but i blown away by the amount of take of acceleration it has.
cheers
FLYR33
https://www.sau.com.au/forums/topic/76999-skyline-r33/
  • Replies 53
check the blue plate in the back left hand corner. a non turbo will say where the engine is RB25DE. a turbo will say RB25DET. Thats how you can tell, if not check the in side dash, if it has a built in boost guage where the rpm tacho is.
these are just some ways that you can tell
https://www.sau.com.au/forums/topic/76999-skyline-r33/#findComment-1409820
Take care it isn't a GTS, those have the SOHC 2.0L engine - will have for the engine designation RB20E on the firewall plate if it is. They are 'somewhat' underpowered....
Most likely it is a GTS25, as mentioned that will have RB25DE on the firewall plate. 200HP from the NA 2.5 means they are fairly quick.....
https://www.sau.com.au/forums/topic/76999-skyline-r33/#findComment-1409917
ok the plate is on the firewall most usually on the left side.
the firewall is at the back of the engine, the wall that seperates the engine from the cabin.
NA means Naturally Aspirated, which means non-turbo.
Hope that clears up some confusion
https://www.sau.com.au/forums/topic/76999-skyline-r33/#findComment-1411440
I've got a Rb20E mate and theyre not that bad, good car to learn on, still pisses on lancers and shit like that, so i wouldnt worry too much if thats what it is, rb25's are good motors, and by the sounds of the 24valve it sounds like one!
Goodluck, and lets hope its a good car!
It should also say on the compliance plate which is a green plate mines on top of the strut tower, and it'll say what make it is and who its complianced by and the date!
Dayne
https://www.sau.com.au/forums/topic/76999-skyline-r33/#findComment-1411549
That's left hand side as you look from the front of the car toward the back of the engine bay. Just to the left of the brake master cylinder.
24 valve - yup, that would indicate a RB25DE (GTS25) as I think the RB20E (GTS) is 12 valve due to the SOHC head?
Dayne - yup, GTS's are still better than a lot of cars out there! Just be sure that you don't pay a premium for one. In NZ the GTSs are significantly cheaper (and thus far more common) than the GTS25s.
https://www.sau.com.au/forums/topic/76999-skyline-r33/#findComment-1414094
THANKS MATE
https://www.sau.com.au/forums/topic/76999-skyline-r33/#findComment-1414363
The GT badge on the side of the car has nothing to do with the cars motor. It is just the famous GT badge associated with Skylines.
In the R33 range as said earlier:
GTS = 2lt Non turbo.
GTS25 = 2.5lt Non turbo
GTS25T = 2.5lt Single turbo
GTS4 = 2.5lt Single turbo or NA + 4wd
GTR = 2.6lt Twin Turbo 4wd
All very good cars. Not a fan of non turbo Skylines though as I think it defeats the point.
I know that coment will cause some tension. i might just run and hide under my turbo...
https://www.sau.com.au/forums/topic/76999-skyline-r33/#findComment-1416015
Got mine at a good price anyways:) considering upgrading to RB20det in it this holidays though.. or 25DE
Dayne
https://www.sau.com.au/forums/topic/76999-skyline-r33/#findComment-1416155
thats like saying getting a standard commodore without a supercharger defeats the point.
https://www.sau.com.au/forums/topic/76999-skyline-r33/#findComment-1416173
I have never heard of an R33 GTS4 Turbo, all the 33 GTS4's I've seen have been NA
The only other single turbo GTS4 I've seen is an R32 GTS4.
and before someone makes a smart arsed comment, GTR's with single turbo conversions dont count :(;)
https://www.sau.com.au/forums/topic/76999-skyline-r33/#findComment-1417072
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
