Gday Guys,
I have another thread http://www.skylinesaustralia.com/forums/sh...017#post1383017 going regarding fixing my camber. I had decided I was going to get all the bushes I need to fix that up, plus get some castor.
However, after I went in a motorkhana on the weekend (first time I have thrown the car around in a sliding fashion) I think maybe I need to look at a better suspension setup aswell.
Here are some pics
http://ribfeast.no-ip.com/mgmotorkhana05/skyline_1.jpg
http://ribfeast.no-ip.com/mgmotorkhana05/skyline_2.jpg
http://ribfeast.no-ip.com/mgmotorkhana05/skyline_3.jpg
Now, I am pretty strapped for cash, and I am NOT interested in throwing lots and lots of money at my car for stuff that I don't really need. BUT...
With that much roll (keep in mind that I was in no higher than 2nd gear, so it's not like I was going fast) should I be looking at a better setup? If so what? Do I just get some decent springs, or do I need to go for coilovers or something. I am 100% NOT willing to spend over $2000. And I am a bit "meh" about spending more than $1000 really. I had planned the castor/camber fix to be up to $1000, so if I was able to kill 2 birds with 1 stone, then maybe we can find a comprimise.
I also need to raise the car as it is *just* under 100mm clearence at lowest point (ie. illegal in NSW)
I plan to use the car as a street car (not street racing...just general usage) I will be doing the occasional track day and drift day. I am going to go to every motorkhana I can get to, but I obviously dont need to spend money on the car for a motorkhana. If I am good at drift (find out next weekend!!) then I will be trying to get to the track every month.
What are my options, and are they really worth it in reality? I am particulary interested in SK's answer.
Thanks in advance
Chris
https://www.sau.com.au/forums/topic/77262-body-roll-advice-please/
  • Replies 42
Uprated springs and shock absorbers won't go astray. I'm personally not a fan of coilovers (the adjustable type) for basic road-cars - just don't see the need for them.
Springs and shocks can only do so much. If you want to stop the body roll with springs only, then you will be up for a kidney transplant inside a week (the ride will be sooooo harsh and stiff, you will feel it when you drive over a cigarette paper!). Anti-roll bars (sway bars) will solve that part of your problem.
Check out www.whiteline.com.au - they have a kit for the R33.
Track and drift are different. You don't want drift at the track. And the suspension setup for one will (probably) be incompatible with the suspension requirements of the other. But as in all things, it's all a compromise.
What the blind_elk said, I would add that adjustable stabiliser bars will enable you to change the balance for circuit, motorkhana and drift. The best bang for buck suspension upgrade by far, ~$450 if you do the fitting yourself (there is a how to guide on the forum). The next best is wheel alignment settings, caster and camber as you have mentioned.
:D
ok so how do I determine what shocks and spring rates I should be looking at?
Something like these http://www.otomoto.com.au/HDSystems/index.htm maybe a good deal. As it seems I can adjust camber on them aswell. I mean that will go towards saving on the camber bushes. Altho I am guessing that it won't be camber adjustable on skylines?
Comments?
Cheers
Chris
Im in the same boat as eXc. I have a stock r33 (suspension wise) and was also looking for cheap handling upgrades. So what i gather from SK's post is that adjustable stabiliser bars would be the best place to start for basic track and drift work.
Also would GTR sway bars be a good upgrade for GTST? Cheers
If you're strapped for cash I'd buy swaybars and drive on them before looking at a coilover kit.
I put dampers in my car (on stock springs) and I only found a marginal improvement in handling after playing around with the settings, but with the swaybars were instantly noticable.
I would say the best cost effective mods are:
Front and rear whiteline Adj Swaybars (about $200 each)
Front castor Kit $160
This gives you a certain level of tune above and beyon tyre pressures.
From here, I would say that front and rear braces are worth good gains (About $165 ea)
(I have an R32 Cusco Fr strut brace for $120)
The next step would be camber bushes (about $80 per pair)
Nope, the 2wd Skylines need larger front bars than the 4wd.  The standard rear bars are way too small on both.:D
Ok the whiteline kits are looking very good at the moment. But would it be really be worth while get the adjustable ones (as oppossed to a fixed one) considering i know next to nothing about suspension setups? Cheers
Adjustable suspension components means you can "tune it" to suit your driving style..
They are only worthwhile if you are going to adjust them. If you just want to put them on and forget about it, then get fixed rate bar and spend the saved money on something that you will use. Adjustable bars are only better if you ADJUST them.
Nope, the 2wd Skylines need larger front bars than the 4wd.  The standard rear bars are way too small on both.:(
The standard rear R33 GTR swaybar is 27-28mm. This is comparable to the whiteline 28mm heavy duty bar. Although they would be made of different materials which could affect the torsion strength.
Standard GTR bars are hollow:cheers:
But the steel is more tensile in the GT-R rear sway bar than the GTS-t, is it not?
I have put the GT-R rear sway bar on and I felt a considerable difference. Could that be simply b/c I upgraded my worn rubber bushes to new polyurethane items? (I think I have over tightened the bushes too!)
The GT-R bar may be made from a thicker-walled tube, which would make it a "heavier" bar, both weight-wise and torsionally. I reckon the Whiteline bar is solid.
Yep, wall thickness is relevant and the Whiteline stabiliser bars for Skylines are most definitely solid, spring steel bar from BHP.;)
IMO For the extra $25, adjustment is no bank breaker but more importantly it allows easy tuning of the suspension from Over steer- neutral-understeer.
If your at the track its not like you can play with heights or spring rates and only a certain amount of "tuning" can be done with simple tyre presure changes
Adjustable bars allow a quick change by repositioning the locating bolts. Takes 5 mins if that!
With a Fixed (or GTR) Bar you dont get any flexibility- Just a cheap upgrade
I agree. with the fact that the money's negligible.
And the other thing is, the guys who make your bars can't guarantee your setup. If you're running different spring and damper rates to their development vehicle, then the swaybar effect you'll need is different.
Even if you only set them once and leave them be its worth it, since you're more likely to have a swaybar that's a good match for your suspension rather than one that's in the same ballpark.
Otherwise, you may as well say that unless you're going to sit there tuning it all the time, why get a programmable PowerFC over a Powerchip or some other "pre-flashed" ECU tune.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
