Hi Guys,
I need a couple of bits. I'm pretty sure it won't matter whether they are from GTST or GTR, but it's for my GTR.
I need:
1 standard MAP sensor (it's the little black box that sits on the firewall, drivers side with 1 vacuum line going in and some wires coming out).
1 pair of sunvisors including the bits they clip into, and the screws to screw them in. I have a set that I borrowed of Duncan many moons ago, and I'm sure he'll want them back. I also had a very nice offer from Paul and Stacey for their set, but found that the clips were just as time consuming to get as the visors so I'm putting the call out again :(
I also would like a pair of the rear grab handles and their screws, but not too fussed about these bits.
please pm me if you have any of this stuff.
Thanks.
i will give them a shot, but I don't think it'll be cheap. :bendover:
surely there must be some people about with complete sunvisors etc? I see R32s being written off pretty regularly.
did you end up calling nissan about the visors???
im curious to see how much they are...
also just a point, the clips are annoying your better of using something else to attach them.
i would NEVER part with mine :rofl:
Mr Beer - when I was in QLD I went to a wrecker and picked up a sun visor for $30. Just have a ring around wreckers who have front cuts ... should be able to find a pair!!
i got a set of sunvisors from an r32 gts-t. make me an offer.
sounds good. do they have the two bits they clip into too? and the screws?
if so we can work something out.
also, I've found the map sensor :rofl:
hi folks, I still need these. Chef kindly offered me his but I discovered that they are a different type of fabric to my interior. mine is the soft fabric type.
Thanks
