  • Replies 117
You think you got the oldest icq number???
Try this out:
ICQ 873042 (hardly used, but I BEAT YOU exstatic!!!) :bahaha:
MSN [email protected]
Feel free to add me...
Rianto
Originally posted by ex-static
yea trillian rocks :)
anyway...
12886924 (wow ive got the oldest icq number out of all of your.. gah.. im a nerd :))
[email protected]
https://www.sau.com.au/forums/topic/7820-icq-msn/page/3/#findComment-131573
In fact I just gava Gerald a call this morning..... and apparently it could finish tomorrow or Thursday... they're waiting for the car back from an auto electrician to bypass the neutral safety starter (otherwise car won't start as it thinks still in gear 'D').
Anyway I can't make it on Wed, so if car is finished, I hope I can drive it home on Thursday. But Gerald still needs to replace my brake pads and suspension bushes.
I dropped the car in last week's Monday evening, so considering the progress it's pretty quick!
https://www.sau.com.au/forums/topic/7820-icq-msn/page/3/#findComment-134072
  • 3 weeks later...
Originally posted by predator666
yep, and in fact Yahoo and IRC. So basically you through one client access all these networks through your normal logins to speak to your friends, etc. Its very nice. Give it a try and see.
does that mean i can access irc from work
cause ive tried to dl it and it wont connect
https://www.sau.com.au/forums/topic/7820-icq-msn/page/3/#findComment-209333
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
