If you're on a tight budget, a rechip of the standard ECU is probably your cheapest (not necessarily best) option.
Even if there was a difference, I imagine most AU GT-R owners will want to hold on to their for resale values reasons anyway.
LW.
I don't think either standard ecu should affect the amount of black smoke the thing produces so that you can see it under accel. a visible amount of black smoke means it's running way rich, richer than a really rich standard ecu should affect richness.
it's all a bit rich, if you know what i mean.
what Duncan said.
what Duncan said.
so a bit rich is allrite? newbie here..
The stock ECU + dead O2 sensors = super rich running, so its not completely impossible.
LW.
no a rich tune won't "damage" anything. its unsightly, and is no good for power, but at least your beast wont lean out and ping!!
i agree with the s-afc route. if you've gotta "bandaid" it until you can go programmable management, the safc makes sense. just sell it on when you do get the pfc.
The Aussie ecu's were re-programed as the maps given to the factory jap GTR's (this is where the australian ones were built and where the ecu's actually come from too) ran too much ignition advance for the lower octane fuels here (back then only 96 octane max), the jap fuels are also higher in benzene based additives that act as octane boosters and require a richer air to fuel ratio. Oh and while they were at it they removed the speed restrictor.
    • Yeah, I guess its pretty easy to get to if this doesn't work. Just wait till next oil change and pull it out. I am going to have to do the oil pan gasket soon and thought I'd just replace it while I was there.  Thanks
    • All that matters is you're safe and you were able to type that post. Hopefully heaps of parts you can recover for the next shell.
