basically you just have to tighten up your aftermarket blow off valve.. or put a plate inbetween your stock blow off valve... or for that fact even remove it and just put a plateover the hole to stop it from being plumbed back or vented... that way the air will have no where to go and ;)... go back through your turbo and out your pod lol... this then making the flutter noise... there are huge debates as to whether or not this royally ****s your turbo.. its know that its not "good" for your turbo, but has been settled upon that on low boost it isnt ogin to wreck your turbo, just perhalps shorten its life.
if you want a VL sounding flutter then you will probably want to get a front mount IC if you dont allready have one as it is said to enhance the flutter noise
ive currently got my stock welded over blow off valve on my car at the moment so i get the flutter... but i usually just have my stock unwelded one on there... just felt like a bit of a change last week :)
-Ruffels
no, it whistles. like Nfsu2, fast and the furious, etc
edit: but you can achieve it to a degree by winding down the spring ie making it tighter. this will cause "reversion" which will cause the chatter noise you are talking about. There is debate as to just how bad this is for your turbo... I think so long as you have air coming out of your BOV (ie turbo is still spinning forward), it's not too bad.
Greetings All.
Oh...I thought the HKS SSQ BOV made this noise...?
Bugger...
Cheers Guys,
--Tonba
SSQV is the perfect sound whistling is the best sound u can ever want to have =) I have it on my 33 and its the best, Supersonic type bov, that makes those Pssh sounds, sounds better on the WRX's.
hmmm hks ssqv sounds like a bird dying or getting sucked into the turbo or something, i don't like it hey.:whatsthat
for the, as you decribed it, perfect bov sound
1. buy a vl turbo
2. make sure its an auto
3. get the biggest bov you can find
4. get a fmic so everyone can see your cars turbo
5. get a pod filter
6. tighten the bov as much as possible
7. sit at traffic lights/pedestrian crossings/intersection and hold your foot on the accelerator and brake at the same time and then back off the accelerator.
8. look around to make sure everyone is looking at you
9. take off doing a sick one wheeler :burnout:
Disclaimer:This is not intended be provoking everyone with vl turbos, only the ones that do shit like this. :sly:
PS back to the point of the thread.
You can get the "fluttering" noise too if you have an external wastegate, different gates make different noises when you back off and some seem to make an almost fluttering noise as you describe.
The bov fluttering noise everyone says is bad as its reversion but my old 33 made the fluttering noise as i had no bov at all and the hks turbo on it had no shaft play last time i checked and still worked well.
Jamie
*makes Cyph3r a badge that says "I have never heard an external wastegate in my life"*
wear it proudly my good man.
perhaps someone with an external wastegate that is open to atmo will see you with it and take you for a spin to let you hear the sound that an external wastegate dumping to atmo actually sounds like.
lmfao *grabs the badge and pins it to my shirt*
i have definately heard one before mate, i wasn't talking about when it is wide open on full boost and it roars, i was talking about on gearchanges.
maybe its just my old car and my mates car that do it and all the rest in the world don't but they distinctly made a segmented rather then continuous noise. on my mates car you could hear the bov was continously open while the wastegate "sounded" like it opened and shut a few times.
Jamie
so describe this sound.. or record it and attach here.
it could just be that the bov wasn't able to vent enough.. and therefore even though it was venting everything it could, there was still some reversion through the turbo..
I really can't see how a wastegate that needs say 15psi of pressure to open could close and open on gearchanges.
I don't see how there can be fluctuating pressure in the exhaust manifold/turbine area during gearchanges which go from 0 to somehting above the spring pressure of the wastegate to cause it to open and shut.
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
