90 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
the way to go is an alarm that you can disable the chirp. say by pressing button 2 the button 1. That way you can have the best of both worlds.
YEP thats the way i have mine set up. Best of both worlds so if your in the ghetto (jk) then u can warn everyone to back the f*#k away from your ride.
Get home at 4am and you dont want to "ALARM" any of your neighbours then its a slient arm :Pimp2:
Yeah thats a good idea, but sometimes the second button doesnt register and it still chirps :mad: I got that on the pathfinder.
mines a total pain in the arse atm... the latex/rubber that the buttons are moulded onto is cracking and has lost it's strength... so chances are every time a bit of pressure (like a tiny bit) is put on the buttons while in your pocket, it arms or disarms. quite annoying when you're getting into the car with keys in hand, and the bloody thing arms
hey guys i got a mongoose alarm, pretty good, it chirps but u can arm it without cjirping by using the second button on the remote. there are two buttons, one for chirping and the other for silent arming!!!! so u get the best of both worlds LOL.
mine has both normal arm/disarm and silent. crap thing is, if say i unlock the car and dont open the door within 15 seconds, it re-arms with the chirp regardless of how i disarm it. i always forget that it does that!
Mine does exactly that. Love it. Very handy. Only problem. Once the engine is off and the doors/boot are closed, I have about 4-5 seconds to arm it before it chirps 3 times. Annoying when you're trying to sneak home. :chairshot
Took me a while to work this function out, thought I was just going crazy, but when i walk to the car, once I disarm the alarm, if I don't open the door within about 30seconds-1min, it rearms itself. Pain in the arse sometimes, but i guess its in case you knock the disarm button walking away.
hmm :confused: anyone else's do that?
Car alarm and immobiliser chrips each time I press the remote button *DUH*
Don't really mind it except for those times when you need to get in and out of your car and people around you just think you're nuts!
Also another thing is the immobiliser self arming, gets me every time as it takes about 15 secs no matter what you do/don't do. Other than that it's fine.... I'd like an option though~
    • I thought the same too, and more than happy for others to bring another source for what it is. Just throwing so me caution out there, as potentially an extra 30% current needed than expected.   Well worth more investigation, but right now, I'm going over my Cypher knowledge while Expendables 4 provides mundane noise in the background, ha ha!
    • If true then....wierd. That's a very high base fuel pressure for a shitty old early 2000s Nissan.
    • I may have my math slightly wrong, I'm not double checking that again, but the factory spec for fuel pressure is to set it with the engine IDLING (in vacuum). That spec is 51PSi while idling. So now add +10psi for atmospheric, and +7 for 7psi of boost, and we need 68psi of fuel pressure at full noise, and 51psi idling. That's according to the FSM I found last night for M35. So MINIMUM fuel pressure should be 51psi and it climbs from there.
    • Provided that what you see makes sense and is not "linear" between, say 1.9 and 2.1 volts and that's the whole range you get. You still need it to be doing one end of the 0-5v range at one end of travel, and the other end of the 0-5v range at WOT.
