Ed G Posted July 9, 2005 Share Posted July 9, 2005 at .99 or 1 bar it should be running heaps more than 3psi... actually even if it's not working, the std wastgate spring should still hold at least ~7psi (~.5bar) Link to comment https://www.sau.com.au/forums/topic/79100-what-do-you-think-r32-gts-t/page/3/#findComment-1455007 Share on other sites More sharing options...
Jadles_R32_GTS-t Posted July 9, 2005 Author Share Posted July 9, 2005 at .99 or 1 bar it should be running heaps more than 3psi... actually even if it's not working, the std wastgate spring should still hold at least ~7psi (~.5bar) I think he might have calculated the guage wrong because we started a fight over it because on the standard guage it was going to about 6 psi (the max being 7 psi) though he was the mech and i wasn't so he was right in his mind. I though it was going pretty alright for 3 psi thats why I questioned it. But I have only had a 4cyl turbo to compare it to, which is not a good compare. I think I'll take it into the shop and ask them what to do about it and get them to teach me. Link to comment https://www.sau.com.au/forums/topic/79100-what-do-you-think-r32-gts-t/page/3/#findComment-1455025 Share on other sites More sharing options...
Ed G Posted July 9, 2005 Share Posted July 9, 2005 what was the evc going too when the std guage went to 6? Link to comment https://www.sau.com.au/forums/topic/79100-what-do-you-think-r32-gts-t/page/3/#findComment-1455030 Share on other sites More sharing options...
Jadles_R32_GTS-t Posted July 9, 2005 Author Share Posted July 9, 2005 what was the evc going too when the std guage went to 6? I wasn't watching, was watchin the road, I'm not used to the car yet, this was yesterday when I was driving it for the second time ever so??? I'll have a look tonight is anyone going to Broady carpark because if you are I can show you there??? If not I might drive to Bris at Midnight. Link to comment https://www.sau.com.au/forums/topic/79100-what-do-you-think-r32-gts-t/page/3/#findComment-1455035 Share on other sites More sharing options...
Ed G Posted July 9, 2005 Share Posted July 9, 2005 Im not headin anywhere tonite.. workin early 2moro someone will prolly be goin down tho Link to comment https://www.sau.com.au/forums/topic/79100-what-do-you-think-r32-gts-t/page/3/#findComment-1455048 Share on other sites More sharing options...
Jadles_R32_GTS-t Posted July 9, 2005 Author Share Posted July 9, 2005 Im not headin anywhere tonite.. workin early 2moro someone will prolly be goin down tho Okay then, hopefully it will be a friendly SAU member Link to comment https://www.sau.com.au/forums/topic/79100-what-do-you-think-r32-gts-t/page/3/#findComment-1455049 Share on other sites More sharing options...
Ed G Posted July 9, 2005 Share Posted July 9, 2005 also keep in mind the standard boost guage is calibrated in mm HG (millimetres of Mercury) ie 760mmHg = 14.6 psi = 1 Bar Link to comment https://www.sau.com.au/forums/topic/79100-what-do-you-think-r32-gts-t/page/3/#findComment-1455054 Share on other sites More sharing options...
Jadles_R32_GTS-t Posted July 9, 2005 Author Share Posted July 9, 2005 also keep in mind the standard boost guage is calibrated in mm HG (millimetres of Mercury) Ā ie 760mmHg = 14.6 psi = 1 Bar Thanks Link to comment https://www.sau.com.au/forums/topic/79100-what-do-you-think-r32-gts-t/page/3/#findComment-1455057 Share on other sites More sharing options...
Ed G Posted July 9, 2005 Share Posted July 9, 2005 here... rough conversion for std guage to psi 0 Guage = 0psi 1/4 = ~3psi 1/2 = ~6psi 3/4 = ~9psi Full 7 = ~13.5psi Link to comment https://www.sau.com.au/forums/topic/79100-what-do-you-think-r32-gts-t/page/3/#findComment-1455061 Share on other sites More sharing options...
Jadles_R32_GTS-t Posted July 9, 2005 Author Share Posted July 9, 2005 here... rough conversion for std guage to psi0 Guage = 0psi 1/4 = ~3psi 1/2 = ~6psi 3/4 = ~9psi Full 7 = ~13.5psi Mine must be running 9 psi then, I have no idea how it works i'm going to have to go and see a specialist Link to comment https://www.sau.com.au/forums/topic/79100-what-do-you-think-r32-gts-t/page/3/#findComment-1455067 Share on other sites More sharing options...
Ed G Posted July 9, 2005 Share Posted July 9, 2005 Mine must be running 9 psi then, I have no idea how it works i'm going to have to go and see a specialist sounds like std boost... have a read thru the instructions... might be a simple answer Link to comment https://www.sau.com.au/forums/topic/79100-what-do-you-think-r32-gts-t/page/3/#findComment-1455071 Share on other sites More sharing options...
Jadles_R32_GTS-t Posted July 9, 2005 Author Share Posted July 9, 2005 sounds like std boost... have a read thru the instructions... might be a simple answer The instructions that you posted of the ones on the web site?? I couldn't get through to the web site Link to comment https://www.sau.com.au/forums/topic/79100-what-do-you-think-r32-gts-t/page/3/#findComment-1455079 Share on other sites More sharing options...
Ed G Posted July 9, 2005 Share Posted July 9, 2005 SBC is the scramble boost button - allows you to increase boost above low/high settings at the push of a button, for a given period of time. You can specify how much boost increase you want and how long you want it to last. There's a connector for an external switch you can mount anywhere.Kind of like the 'overtake boost' feature of some of the newer units English EVC III instructions, pdf, right click save as there ^^ edit - try now Link to comment https://www.sau.com.au/forums/topic/79100-what-do-you-think-r32-gts-t/page/3/#findComment-1455080 Share on other sites More sharing options...
Ed G Posted July 9, 2005 Share Posted July 9, 2005 if they dont work i can email it too you Link to comment https://www.sau.com.au/forums/topic/79100-what-do-you-think-r32-gts-t/page/3/#findComment-1455090 Share on other sites More sharing options...
Jadles_R32_GTS-t Posted July 9, 2005 Author Share Posted July 9, 2005 if they dont work i can email it too you It worked that time I'm just reading through it, thanks Link to comment https://www.sau.com.au/forums/topic/79100-what-do-you-think-r32-gts-t/page/3/#findComment-1455093 Share on other sites More sharing options...
Ed G Posted July 9, 2005 Share Posted July 9, 2005 no probs Link to comment https://www.sau.com.au/forums/topic/79100-what-do-you-think-r32-gts-t/page/3/#findComment-1455095 Share on other sites More sharing options...
