  • Replies 378
Sorry for the brief answers, this thread is for guys to measure their springs and for me to calculate the rates, please post any follow up questions in the general suspension thread and I will answer them or PM me if you want.
does the spring rate have to suit the car for eg, i have a r33 gtst
Yes
what is the rate on stock springs?
~165 lbs/inch (3 kg/mm)
what would i be looking to get if i were to get coilovers?
Depends on;
1. what you use the car for
2. what tyres (normal road tyres, R type track tyres or full slicks)
3. what antiroll rates (stabiliser bars)
4. what dampers rates (in the shocks)
5. the suspesnion geometry (anti dive and anti squat)
would it be the same spring rate as stock?
Not normally.
does springrate stiffen/soften ur ride,
Higher spring rate generally (not always) results in a firmer ride.
:cool: cheers :)
HiSk,
Can you help me measure up the spring rates for the Tein HA coilovers please? I only had them measured the Springs which are round and not the flat bits at the bottom end of the spring.
Front.
Coil OD :116mm/97mm
Wire OD :14mm
# of coils : 6.5.
Rears.
Coil OD :95mm/95mm.
Wire OD : 14mm
# of Coils : 8.125
Thanks Buddy.
  • 3 weeks later...
I had a look through the threadbut couldn't see any standard spring rates?
I'm after the standard front and rear spring rates in Kg's for an R32 GTS-T. If it has been posted but I missed it, please don't burn me!
  • 3 months later...
Got bored one day when I wanted to work out my spring rates for the ohlins coilovers I had a tried to guess the spring constant rate Sydney Kid's program was using using some basic mathematics.
Unfortunately I could never get it quite right :P, but if anyone has an idea of how to fix my little excel spreadsheet calculator please PM me :)
Attachment fixed, excel files are not allowed :(
spring_rate_calculatorv2_excel97.zip
Edited by some_cs_student
~165 lbs or 3kg/mm
Cheers
Gary
Hey mate. Could you please tell me the rates of my rear DAB Gymkhana's on my S13?
Coil ID = 74/74 mm
Wire OD = 10 mm
# of Coils = 7.25 turns
Spring rate = 175 lbs/inch (3.1 kg/mm)
Thank you.
HiSk,
Front.
Coil OD :116mm/97mm
Wire OD :14mm
# of coils : 6.5.
265 lbs/inch 4.7 kg/mm
Rears.
Coil OD :95mm/95mm.
Wire OD : 14mm
# of Coils : 8.125
Thanks Buddy.
Hey Sydneykid,
Do you happen to know what stock R34 GTR (or R33 GTR) spring rates are? I've been told R33 GTR and R34 GTR standard springs are the same.
Just curious so I can compare the rates to my ohlins :banana: (in an R33 GTR)
Ahh found this post that you had posted earlier in the thread:
Sorry, not an easy question to answer, there seems to be a few different standard spring rates in R34GTR's. I have seen three different rates, standard R34GTR, V Spec and N1 (maybe NUR spec), there may be others. The lightest was 165 lbs (3kg/m) per inch and the heaviest was 205 lbs per inch (3.7 kg/mm).
And on this one:
Keep in mind that GTR's handle best around 355 mm front and 345 mm rear (centre of wheel to guard).
My car currently has a bodykit so its waaay above 355/345 to be legal. Also, I thought the rear-end would be higher?
Is that wrong?
I think my car is 370mm/375mm, to keep just over 12cm off the ground on the front bar (may be a little less), I just want to stay about the 10cm legal height in Vic ;). It may also have aftermarket front guards, I'm not sure (they feel like there made of fiberglass).
The car looks like its sitting evenly (as in start and the end of the sideskirts) and seems to handle pretty well but I've only done one advanced driving course, not enough hard driving to know for sure.
Regards,
Gareth
Hey Sydneykid,
Just curious so I can compare the rates to my ohlins :no: (in an R33 GTR)
And on this one:
Is that wrong?
I think my car is 370mm/375mm, to keep just over 12cm off the ground on the front bar (may be a little less), I just want to stay about the 10cm legal height in Vic :). It may also have aftermarket front guards, I'm not sure (they feel like there made of fiberglass).
Regards,
Gareth
Hi Gareth, the rear guards are cut 15mm lower, so my recommended centre of wheel to guard measurement (355 mm front and 345 mm rear) actually gives a rake of ~10mm nose down. Rake is best measured at the sills, just behind the front wheels and just in front of the rear wheels. Most body kits have the cut outs there for the jacking points.
Cheers
Gary
  • 4 weeks later...
Hi Gary,
just had my Cusco coilovers taken out:
coil ID 70mm
wire OD 13mm
# coils 8 on the long one ( is this front or rear? - obviously I'd know this if I took them out myself)
# coils 7 on the short one
cheers,
Mike
Hi Gary,
coil ID 70mm
wire OD 13mm
# coils 8 on the long one - rear 450 lbs/inch (8kg/mm)
# coils 7 on the short one - front 550 lbs/inch (10 kg/mm)
cheers,
Mike
Cheers
Gary
Wouldnt the spring hardness and material effect the rate ?
How can you tell rates without knowing that ?
Or does it assume everything is a "standard"
Ignore that bit you have already answered it several times .....
Hey "I was elected to lead , not to read"
My Ohlins just happen to be on the garage floor
Front
13.8mm wire
7.5 Coils
92.5mm od
Rear
13.2mm wire
9.25 Coils
92.5mm od
In my opinion , they are hard ...
:P
Edited by RS581
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
