  • Replies 378
Coil OD = 60/60 mm
Wire OD = 10 mm
# of Coils = 7.5 turns
a lil ruff but best i cud do at the time
thanks :thumbsup:
60 mm OD = 40 mm ID, I have never seen a spring that small.
If you meant 60 mm ID, then;
Spring rate = 290 lbs/inch (5 kg/mm)
Cheers
Gary
yep my bad ment ID
looks like i need harder springs, still better then the stockies tho :laugh:
OK front rate for road tyres, a bit under done for R type tyres though.
Cheers
Gary
  • 3 weeks later...
Hey Gary looks like your the man for this sort of stuff
could you have a go at these coilovers??
Rear:
lower coil OD: 95
upper coil OD: 110
wOD: 13.5
no. of turns: 7
front:
lower coil OD: 100
upper coil OD: 120
wOD: 15
no. of turns: 6.25
cheers
Rear:
lower coil OD: 95
upper coil OD: 110
wOD: 13.5
no. of turns: 7
Spring rate = 350 lbs/inch (6 kg/mm)
front:
lower coil OD: 100
upper coil OD: 120
wOD: 15
no. of turns: 6.25
Spring rate = 500 lbs/inch (8.7 kg/mm)
cheers
OK spring rates for slicks, too high for everything else.
Cheers
Gary
Front:
Coil ID = 104/90 mm
Wire OD = 12 mm
# of Coils = 9.8 turns
Spring rate =
Rear:
Coil ID = 99/71 mm
Wire OD = 12 mm
# of Coils = 9.4 turns
Spring rate =
I believe they're Nismo low springs, not sure though...
Cheers.
Edited by _Scotty_
Front:
Coil ID = 104/90 mm
Wire OD = 12 mm
Spring rate = 120 lbs/inch (2 kg/mm)
From that low spring rate I assume that they are progressive. To get the actual (in use) spring rate you need to look at the coils, there should be some very closely wound together. They are sacrificial coils, they collapse onto each other as soon as the weight of the car is applied. Those coils need to be left out of the calculation.
Otherwise check the wire diameter.
Rear:
Coil ID = 99/71 mm
Wire OD = 12 mm
Spring rate = Spring rate = 170 lbs/inch (3 kg/mm)
These may be progressive as well.
Cheers.
Coil ID = 146mm
Wire OD = 12 mm
# of Coils = 5 turns
Spring rate = Spring rate = 95 lbs/inch (1.7 kg/mm)
Esplier springs apparently.
Is that a parrallel coil, ie; 146 mm all the way?
Cheers
Gary
Front:
Coil ID = 104/90 mm
Wire OD = 12 mm
Rear:
Coil ID = 99/71 mm
Wire OD = 12 mm
Correct, they are progressive, so how about:
Front:
Coil ID = 104/90 mm
Wire OD = 12 mm
# of Coils = 5.5 turns
Spring rate =
Rear:
Coil ID = 99/71 mm
Wire OD = 12 mm
# of Coils = 7.4 turns
Spring rate =
Any idea if these are in fact Nismo springs?
Cheers Gary.
Front:
Coil ID = 104/90 mm
Wire OD = 12 mm
Spring rate = 250 lbs/inch (4.4 kg/mm)
Rear:
Coil ID = 99/71 mm
Wire OD = 12 mm
Spring rate = 230 lbs/inch (4.1 kg/mm)
Cheers Gary.
They are fairly sensible rates, which Nimso do occasionally.
Cheers
Gary
Hey SK, springs in my old tanabe coilovers which I am thinking of putting back in measure like this:
Front:
Wire OD: 11.5mm
# Turns: 6.9 (2 sacrificial coils i think)
Rear:
Wire OD: 11mm
# Turns: 7.8 (2 sacrificial coils i think)
Some measurements seem odd but with digital callipers its difficult to get an repetitive reading, it seems that with the fronts they were thicker in the middle then the top and bottom but only by .5 mm so I just ignored it. Also the top and bottom of the coil are manipulated flat (2 sacrificial coils i think) so I don’t know if that affects anything but I would say most coilover springs are like that. They also have the little helper spring but as mentioned earlier that holds the main spring in and doesn’t affect the spring rate?
Do you know anything about the tanabe coilover shocks? They are height adjustable but not damper adjustable and are from the sus tec pro range (many years old).
Thanks in advance!
Edited by vespa
Front:
Wire OD: 11.5mm
490 lbs/inch (8.7kg/mm)
Rear:
Wire OD: 11mm
370 lbs/inch (6.7kg/mm)
Thanks in advance!
Spring rate is obviously way too high for road work, even too high for track work unless you are using slicks. The best (cost effective) recommendation I can give is to stick the rear springs in the front and buy a set of rear springs around 225/250 lbs/inch (4 to 4.5 kg/mm). Tanabe shocks are OK in a typical Japanese way, not good but OK. Try the spring swap and see how you like it.
Cheers
Gary
rear coil:
top 100
bottom 80
wire 10
turns 9
thanks
Are the top and bottom measurements the inside diameter? If so 80 lbs/inch (1.4kg/mm), which is very low.
Are they progressive coils? A number of coils that collapse onto one another as soon as the weight of the car is applied to them? Hence reducing the number of effective coils.
Usually around 4 coils, in which case the rate would be 180 lbs/inch (3.2 kg/mm)
Cheers
Gary
Can you knock these out for me, measurements may be off a touch as did them with shocks still on car & there was minimum room...
Note: springs are progressive, top 5 coils are wound tight, others are normal.
Fronts
Lower O.D. = 89.3mm
Upper O.D. = 89.3mm
Wire thickness = 12mm
No. Coils = 11.125
Rears
Lower O.D. = 85.6mm
Upper O.D. = 87mm
Wire thickness = 11mm
No. Coils = 11.125
thanks heaps!
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
