Can you knock these out for me, measurements may be off a touch as did them with shocks still on car & there was minimum room...
Note: springs are progressive, top 5 coils are wound tight, others are normal.
Fronts
Lower O.D. = 89.3mm
Upper O.D. = 89.3mm
Wire thickness = 12mm
No. Coils = 11.125
270 lbs/inch (4.8kg/mm)
Rears
Lower O.D. = 85.6mm
Upper O.D. = 87mm
Wire thickness = 11mm
No. Coils = 11.125
210 lbs/inch (3.7kg/mm)
thanks heaps!
Cheers
Gary
  • Replies 378
Cheers
Gary
wow, ok I think I've stuffed up a measurement then because mine are rock hard & those spring rates are close to stock (z32).
Im assuming the springs are progressive as the top coils are wound a lot closer than the rest but perhaps Im wrong, any suggestions where I've messed up?
Coilovers are HKS Hipermax's & from what I can tell the lowest rates available (across whole range for z32) where fr=7, rr=6.
cheers, tim
cheers, tim
Can you post a picture Tim? That may show me what the progression is.
Otherwise you will have to measure the gaps between the coils. They should measure something like this,
3 mm / 5 mm / 5 mm / 5 mm / 15 mm / 20 mm / 20 mm / 20 mm / 20 mm /15 mm / 3 mm
Cheers
Gary
Cheers
Gary
yeah no problem, will double check measurements & snap some photos over the weekend.
thanks again.
this is rough but here it is for front springs hks hyper d's.
there are a few larger progressive rate coils nearer the top all wound in the one coil. there are 3 of them. Coil ID is 1)66mm 2)71mm 3)66mm
Coil ID = 61/61 mm
Wire OD = 12 mm
# of Coils = 10
could you work this out for me Gary.
Cheers!
Ok Gary heres a couple photos with spacing included on them.
Fronts:
Coil Dia. = 12mm
Top/Bottom O.D. = 89.5mm/89.5mm
No. of Coils = 11.125 (about half of the last coil is shaved so that spring sits flat)
Rears:
Coil Dia. = 11mm
Top/Bottom O.D. = 86.7mm/87.7mm
Have included Dia. of every coil on the rears as the change was more noticable, can get the fronts too if need be.
thanks for the help.
cheers, tim
Fronts:
Coil Dia. = 12mm
640 lbs/inch (11.5kg/mm)
Rears:
Coil Dia. = 11mm
475 lbs/inch (8.5kg/mm)
cheers, tim
Coil ID = 61/61 mm
Wire OD = 12 mm
# of Coils = 10
Cheers!
Assuming 7 active coils (3 progressive)
580 lbs/inch (10.3kg/mm)
Cheers
Gary
Front Coil
Upper OD = 113.95
Lower OD = 108.25
# of Coils = 9.25
Wire OD = 12.85
Rear Coil
Upper OD = 125.00
Lower OD = 112.25
# of Coils = 5.25
Wire OD = 13.7
Thanks. :-)
Front Coil
Upper OD = 113.95
Lower OD = 108.25
# of Coils = 9.25
Wire OD = 12.85
150 lbs/inch (2.7kg/mm)
I assume it's progressive wound, to get the correct effective rate you need to count the number of active coils, there will be around 4 to 5 coils that are inactive once the weight of the car is applied.
Rear Coil
Upper OD = 125.00
Lower OD = 112.25
# of Coils = 5.25
Wire OD = 13.7
350 lbs/inch (6.3kg/mm)
Thanks. :-)
Cheers
Gary
SYDNEY KID CAN YOU CONTACT ME !!! YOU`VE SENT ME THE WRONG SUSPENSION KIT. I HAVE R34 NOT R33. STOP IGONRING ME PLEASE.
Nobody is ignoring you. We get 40 to 50 PM's and emails a day, sometimes I have to actually do some work so I don't get to answer every PM and email every day. But I can assure you every single PM and every single email gets answered in the order in which we receive them. Sticking posts in innapropriate threads won't help you jump the que.
Cheers
Gary
top: 115mm
bottom: 75mm
# of coils: 9 and a bit
wire: 14mm
thanks
230 lbs/inch (4.1kg/mm)
If they are rears then they are most likely progressive, like this
http://www.skylinesaustralia.com/forums/up...61890_thumb.jpg
If yours are like that, then you need to tell me how many coils are close together, they are inactive coils. To work out the real spring rate I need to know the number of active coils.
Cheers
Gary
  • 3 weeks later...
Coil OD = 125/100 mm
Wire OD = 14 mm
# of Coils = 7.5 turns
Coil OD = 110/90 mm
Wire OD = 13 mm
# of Coils = 7.125 turns
Coil OD = 125 mm
Wire OD = 15 mm
# of Coils = 9 turns
Coil ID = 65 mm
Wire OD = 13 mm
# of Coils = 6.75 turns
NB. 3 ODs and 1 ID
Can i please get them in KGmm and Lb"
Thanks Heaps
James
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
