I don't normally buy Hot 4's but I will make an exception this time:D
Also checkout the AutoSalon Mag, the Street Car of the Year issue, it has a writeup on Perth Drag Combat, has a photo of Bully, and mentions all the winners:D
Saw that its costs me s fortune in magazines this month lol
https://www.sau.com.au/forums/topic/79170-rice-makes-hot4s/#findComment-1443881
