  • Replies 78
I've got the Uniden UH040XR (the $99 job from DSE) and it works fine. I decided to tune in this arvo on the way home from work, and got a strong signal (obviously from someone probably at home with a nice big aerial and good output) but couldn't hear the guy talking back to him. I was going down Church St in Nth Parra, right near DSE, as a matter of co-incidence.
Anyway, I've had it since just before the Central Coast meet (thru Terrigal, the Entrance, etc) back whenever, and it was pretty damned handy. I use it mostly when I'm heading up that way (F3 Northbound) to go and visit my cousin (blukie from SDU) who lives a bit past Lake Munmorah, and I think he uses it (he has one too) just about every other day on his way to and from work right near most of you Nth Sydney guys (and girls?)...
Speaking of batteries, I had some dodgy cheapo ones in there, and although I hardly use it (not much point in and around Parramatta), they're finally up for replacement.
  • 4 years later...
corine, this thread is 5 years old... lol.
as for you mars, hardy har. but everyones a funny guy until I start whacking away with my ban stick :thumbsup: lol now that's funny! :rofl:
*** ATTENTION ***
Please try and consider the attached channel allocations when picking channels to talk on. It bothers me slightly every time someone suggests chatting on channel 33, as 33 is a repeater channel for channel 3. If you're near the channel 3 repeater your conversation will be heard over a much wider distance than intended (and you won't benefit from the repeater, it'll simply annoy other CBers).
this has been a public service announcement because I am anal retentive.
UHF_CB_Channel_Allocation_Guide.doc
Jeez Marsss, you would have had to be using some seriously heavy duty earth moving equipment to dig up such an old thread... Did you discover any diamonds or dinosaurs while you were down there?
as for you mars, hardy har. but everyones a funny guy until I start whacking away with my ban stick :) lol now that's funny! :domokun:
Now why would you ban me if there's information on here that is clearly of interest.. (whores swarmed to it)
Apart from this.. we can see old posting styles from the old schoolers or should i say... ex-whores who are now basically over it, and just watch...
so... i've recovered two important points..
Information
Entertainment
that..
is all.
  • 4 months later...
*** ATTENTION ***
Sorry to bring this up again...
More info:
http://www.acma.gov.au/WEB/STANDARD/pc=PC_1265
There are specific channels in the two CB radio bands available for use in an emergency. These are channel 9 (27.065 MHz) in the HF band and channels 5/35 (476.525/477.275 MHz) in the UHF band.
These channels are designated for emergency messages only and, under the class licence, must not be used for other purposes
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
