  • Replies 105
i have the r32 gtst manual (25447kb) do you still need it?
That would be grouse mate, I would love to get my hands on it as I'm just goin through all service and mild improvements every weekend bit by bit and it does help when you know where is what. Do I still need Acrobat 7.0 do get it of ya? ;)
:blink: Thank you , Thank you, Thank you
Links you are legend, Thank you and all other guys who contributed to crankroom manuals being available for download.
I nominate LINKS to be imortal member of SAU!!! ;) Cheers
  • 3 weeks later...
Hi All,
I've recently bought my skyline! I just love it - a black, R33 GTS25T and lowered. Have got to say that is one good manual site...just wished I'd seen it before I bought mine about a week ago :ph34r:
Anyways it's probably been asked before, but since my car didn't have an insturction manual, there were two questions I had: Thx in advance
1) I was wondering if it was normal for the HICAS light to come on and the go off a second or so after starting up the car. It never comes on while driving.
2) My oil pressure light stays on for about 2 seconds and then goes off which is when the needle on the oil pressure gauge starts to move when I start up the car..this is normal right? As far as I know, the oil pressure levels vs. RPM are ok as far as I can tell...am I being paranoid?
They are nice cars!
Cheers fellas!
Most cars run through a self diagnostic when they start up.. it's when they don't light up you get worried :(..
nah it's normal.. hicas & abs & oil will all come on.. than go off.. oil should go up to about 6 until it's warmed up.. than head down to about 2 - 4 operating pressure..
glad you enjoy the manuals..
Phew, thats reassuring! Since when I checked it out, my mate who was with me at the time was getting more excited than the dealer! Took it for a short drive and before I realised it he's encouraging me to leave a deposit :D
Anyway, I'm pretty broke atm but eventually I want to put a cat back exhaust system in and a direct cold air intake. I heard that's supposed to put power up into the 200+ kW @ the flywheel alone! I want the car to still sound the way it does now though..kinda like a low growl...subtle but nice.
After that, tint the windows, put a nice pair of seats in like Duncan's and a proper head unit...and a new bonnet with a subtlely stylish but functional scoop to lower under bonnet temp.
Really want to change the oil and oil filter along with the spark plug and fuel filter myself but that might take a bit of developing my knowledge first!
Well, thats the excited ramblings of a new owner for now.
Cheers,
AF
all of those are pretty easy to do yourself, have fun!
thanks for the uploads Links, been looking for a while...
No worries Joh - AF man.. don't look @ the fly - count @ the rear wheels :P..
As for spark plugs and so forth - depends on what year the car is... everyone recommends oil + filter + spark plug change- depending on where you get it from if it's just been compliance oil + filter should have been done..
Good luck with it..
Thanks guys for the tips! But guess what? I was late for work one day and I swung my car into a tight park between another guy's car and the steel support beams...guess which one I hit??
It was the post - on my left rear panel just after the door :D Now I've got this mad scratch about 30cm lond and 15cm wide that looks like a giant car was sharpening its claws on the side of my car...it was barely one week old at the time :):D
  • 3 weeks later...
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
