  • Replies 58
Yea the blue GTR is one mad machine. It was running a very tame setup at track day as it is yet to have its power tune. Next track day expect to see nearly double the power, 9" slicks on the front, 10" slicks at the rear, side pipes etc and have a look under the bonnet !!
It was a good day, despite the rain.
I only had to pull three vehicles out of the kitty litter - Good old Cruiser.
The next track day on the 30th November is going to fill fast, so please secure your spot ASAP.
Can't wait to see Michael's Blue 32GTR in full force next track day, Paul may even get some laps in his 32GTR.
Regards,
Tim
I've added the wet times :D
Next one is the Grand Finale of the year on November 30. Stay tuned for the email soon.
Paul
if we can get enough interest can we have one earlier then Nov30 ?? and what about having it on a Saturday or Sunday ??
Paul you have email RE Photos
I also have a few photos will post soon.
Who ever owns the Red RX7, PM me as I have a great sequence of shots of your little indescretion coming onto the main straight :lol: Mud flying everyhwere :P Leave me your email address & I'll email them to you.
I also have good sequence photos of drifting the same corner from a couple of other silvias Car #25 & 26#. PM with your email address as well and I'll do the same. I'll leave the details of any other cars I have good photos of in this thread as I work through them.
Bring on the next one!
Cheers
Edited by TOY 33
SirSkyline,
You can email me at: [email protected]
Else you have my home email address from the track day mailing list. Although I will be trying to swith to the above as I now get heaps of offensive spam since I started track day.
Question for any administrator that may read this:
I am trying to convert to the MountainRunner login as it is the same as my login on other forums. Is it possible to change ownership of my Time Attack records thread from gtrman1992 to MountainRunner ?
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
