$18000 3years ago PP
$2000 on PSSEXS Exhaut dimanics VG
$2000 on FMIN+PBBOV Xspeed VG
$200 pod Cypher VG
$915 E boost 2 Xspeed VG
$350 strut braces
wasted
$1000 on SAFC2 d1 version blue up after 2 days by psi there were Terrible
  • Replies 68
hmmm just cracked the 40g all up (20g for car)mark myself. As everyone knows, there's always something else you need. Yes we have cars as money pits. Just ask yaself, what else would you spend ya money on if ya didn't have a skyline ??? Maybe a house, but that's about it.
If ya girlfriend or wife says you spend too much money on ya car....Tell her that you could spend a million on her but she won't do 12's down the quarter mile :D
Im one of the little spenders at the moment but its in the process of changing.
To date i have only spent the following
-Gauges-500
-Rims-2500
-Bc-35, bought one of those manual ones from mark. his thread is in the forced turbo section,awsome bit of equiptment.
-tinted windows-300
other than that not a lot. Some of the mods were already done like tein fully adjustable suspension, pod filter, 3" from the turbo back.
have plans for a fmic soon in the next year for only 700, then it will continue from there.
Love these cars, its just funny how silly little comodores keep trying to run against me, even though mine is a mild tune, so i can only imagine how some of the guys in this forum must blow them apart.
By the way Packy love the comment about the missus.
way 2 much but its fun 2 drive and its what i want.
i'm with u Jason...
too scared 2 put a figure on it, but with new engine/gearbox i'm having so much fun i forget about price anyway...
If ya girlfriend or wife says you spend too much money on ya car....Tell her that you could spend a million on her but she won't do 12's down the quarter mile :)
thats true. atm im only 18, so 90% of the money i earn goes to the car :lol:
nice avatar pic btw, 33 as a rally car, hmmmm :lol:
Edited by **JaR**
Theres at least $5k there on engine mods to get it running mid 12's , not bad when you think of it that way.  What else can beat it for the money?
A CBR1000RR fireblade doing low 10's for $19000 new from the dealer :D
Had my R33 for over a year...
cost $18k imported and on the road
$40 to replace the buggered rear speakers
$15 for new wiper blades
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
