Hey Guys
1993 GTR R32 Vspec
R33 N1 engine
HKS GTSS turbos
HKS cams and cam gears
Cusco coilovers
Greddy intercooler and inlet piping
HKS oil cooler
300 ZX air flow meters
Power FC
HKS exhaust
Advan 17 inch wheels
Upgraded castor rods and sway bars
Upgraded clutch
HKS boost controller
Greddy turbo timer
Recaro seats
HKS super sequential BOVs
Brembo brakes
After market dash
upgraded fuel system
500+ HP
Body kit and wing.
Extremely fast.
No pics until complied.
Michael
https://www.sau.com.au/forums/topic/81439-r32-vspec-bombed-33k/
If the car has just been complied, why has the price gone up please?
Hey Guys
I need 20K up front and 7K after compliance. This is dirt cheap as I need cash ASAP. Take advantage.
Car is in the country and ready to be complied. Can do written agreement etc.
Michael 0414561121
1993 vspec GTR
85,000 kms
N1 engine
Advan wheels
Aftermarket exhaust.
Trust intercooler and piping.
Suspension
And much more.
Hey Guys
Have been offline for a while so will repond to questions soon.
Car is at compliance now.
Car is a Vspec BNR32-305136.
(Have checked this number in Japan and Aus: car has vspec oil cooler, brembos, etc)
N1 block etc (will provide number soon)
Will have pics after car is tidied up. Many things had to be changed for compliance.
M
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
