after a fair bit of money spent this is how a project is going after an engine shitting itself and being rebuilt
rb20det
polished
balanced
o-ringed
arias pistons - taken out 20 tho
better valve springs
had the head machined
copper head gaskets
billent adjustable cam gears going in
oil catch can
high mount exhaust manifold
to4e turbo
700x300x78 fmic 3" piping
38mm wastegate
pod filter
bosch 040 fuel pump- might change
3" turbo back exhaust
wolf 3d series 4 ecu
with this set up wat kinda power can be expected? any suggestions on anthing missed? there has been alot of money spent so far as you can see on the list, any help would be greatly appreciated
https://www.sau.com.au/forums/topic/81870-how-much-kw-will-it-get/
These arent really recommendations , more like questions:)
Any reason why you put valve springs in but kept the std cams?
Also it may have been worthwhile to go a lot bigger then 20 thou, you could have easily bumped up displacement to 2.2L with pistons alone.
Also what have you done in the way of rod bolts for the std rods?
Also i wouldnt decompress the engine any more then the std 8.5:1, also i noticed of late some of the cheaper 3" exhausts are in fact 3" ie 76.2OD whilst a lot of the Jap so called 3" exhausts are actually 80mm...
gtr injectors,and yeah-the to4 will b good for 1.5 bar, yeah got cam gears,std camshaft. he will be changing other things over time. "Also what have you done in the way of rod bolts for the std rods?" umm nothing i know of, any advice would be greatfull though, just need to know what else is necessary, rods? crankshaft?
To4e? why are people using OLD t04's when there is a shitload of new range turbo's out that spool earlier and produve a much nicer power band :)
sadly enough tho with the money spent on that you could have dropped in a rb25 given it a power fc turbo upgrade with injectors.. and it would probaly go alot harder and easier to drive than the dirty old t04e
yeah, mate, you should do that, it would be really good :)
he wanted a powerfull rb20, he now has a powerfull rb20.
you would be surprised how much money was actually spent.
Either way, were you going to give some advice? thats why we started this thread.
oh- and the to4 is new or...hasnt been used.
is there anything that he could have missed? thx guys.
I put an RB25 into my 32 and was rapped, originaly i wanted to build my 20 and have a crazy 20 but when it came to spending the bucks Ben from Racepace advised me that the 25 will make a bit more power at the end of the day so i was sold. I ended up doing the forged pistons, gtr rods, tomei cams 550cc injectors, power fc, hks 3037 proS, fmic and 3.5inch exaust. very happy with the job that was done going to make about 280kw at the wheels on about 17-18pnds.
could'nt be happier with the turbo choice. Perfect for the street not laggy at all.
I wanted to do the same thing.. get a powerful rb20 in my silvia.. but how ever with the money that i was goin to spend i was better off just buying a 26 and getting similar power out of a stock rb26 with mild upgrades.. and still have a safe reliable engine..
dont get me wrong.. rb20's are awesome little motors.. but they just dont have wat it takes to get alot of power out of
240 rwkw so far, highflowing the t04, not alot of power:P we will see how we go after its done
  • 1 month later...
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
