hey ppls.
I'm looking at a new turbo (high flow) soon, and I have seen a fair few turbos lying around in various forms over my time.
When you spin the wheels by hand, some spin heaps some not at all.
Plain bearing turbos dont spin at all after your finger comes off.
Ball Bearing turbos spin a few revolutions, but some keep spinning for a long time after the car stops.
This HAS to be a good sign that the turbo is free to spin as much as it likes.
So, is there a special bearing or something that makes this happen?
Is it a Ceramic bearing that does it?
Do the GCG high flows do it?
All Help Appreciated.
BASS OUT
Hi Bass, I know that my HKS GT2535 unit will spin for about 10-20secs after my car is turned off, even if i only turn it on for a min, move it 10m to make room for my housemate getting out of the drive then turn it off again. That's a ball bearing turbo but whether or not it's a special type of ball bearing, i have no idea.
Sorry, can't comment on GCG highflow.
Just a good garrett ball bearing i would say, i know that a guy down here has a ball bearing turbo on his S2000, and just b4 he shuts the engine off he give it a short rev and the thing spins down for about a minute!
I've had a few turbo's in and out of the car. All stock Nissan items. VG30DET, RB20DET etc.
Off the car they spin freely but don't really keep spinning when I let go of them.
Once installed on the car and they get some oil pressure in to them if I pull off the piping and then spin them they will spin for quite some time if I give it a little spin by hand.
I often hear the stock item spinning down after idle.
I've had a VG30DET on the old RB20DET and pulled it off because it laaaged too much.
But yes.. I've got injectors etc now so I can bolt the vg30 turbo on.
Uni's started back up so its finding the time. :P
This new years I'll be buying a GT30 SB8006A chra and .7 comp cover and have the vg30 turbine housing machined up to suit.
Should work well and be a little more efficient at higher boost levels due to the .7 comp cover.
how a turbo spins when its off the car and you spin it with your fingers is not a good indication of how free it spins!
depending on whether its new, used, has a bit of dust in the core, getting dry, etc... you'll find many second hand turbos that have been sitting wround a while to feel gluggy and not spin very well, but get them on the car and you'll hear them spin down after shut off.
i believe any half decent ball bearing turbo that has steel wheel will spin for some time after shut down. not so much the stock ceramic stuff, maybe not enough inertia in the wheels to keep them spinning for long after you turn off.
hey ppls.
BASS OUT
Hi Pete. I don't know if GCG uses these all the time buy they built mine with Ceramic Angular Ball Bearings.
Ian
So he revs it up, spins the turbo up and turns off the ignition which shuts off the oil pump/feed. Wow, really smart, hope he doesn't expect his turbo to last long :D
spinning it with your hand would be alot slower than it spins when being pushed by exaust gas. Also doing it once or twice with your fingers wouldnt matter, but doing it everytime you turn your car off, can't be good for it?
Not a great idea but these are more for longevity rather than response. The bearings add weight to the rotating parts. A good plain bearing should have no contact as it floats in the viscous oil pulled around the journal. It will not last as long though, but well cared for will give a good life.
I would gesss that most ball bearing turbos would have a small amount of pre-load in the bearing so that when it has been run for a while it comes within optimum tolerance. Heat would also play a factor as only .01mm difference would be needed to dramatically change how well it would spin.
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
