hey ppls.
I'm looking at a new turbo (high flow) soon, and I have seen a fair few turbos lying around in various forms over my time.
When you spin the wheels by hand, some spin heaps some not at all.
Plain bearing turbos dont spin at all after your finger comes off.
Ball Bearing turbos spin a few revolutions, but some keep spinning for a long time after the car stops.
This HAS to be a good sign that the turbo is free to spin as much as it likes.
So, is there a special bearing or something that makes this happen?
Is it a Ceramic bearing that does it?
Do the GCG high flows do it?
All Help Appreciated.
BASS OUT
Hi Bass, I know that my HKS GT2535 unit will spin for about 10-20secs after my car is turned off, even if i only turn it on for a min, move it 10m to make room for my housemate getting out of the drive then turn it off again. That's a ball bearing turbo but whether or not it's a special type of ball bearing, i have no idea.
Sorry, can't comment on GCG highflow.
Just a good garrett ball bearing i would say, i know that a guy down here has a ball bearing turbo on his S2000, and just b4 he shuts the engine off he give it a short rev and the thing spins down for about a minute!
I've had a few turbo's in and out of the car. All stock Nissan items. VG30DET, RB20DET etc.
Off the car they spin freely but don't really keep spinning when I let go of them.
Once installed on the car and they get some oil pressure in to them if I pull off the piping and then spin them they will spin for quite some time if I give it a little spin by hand.
I often hear the stock item spinning down after idle.
I've had a VG30DET on the old RB20DET and pulled it off because it laaaged too much.
But yes.. I've got injectors etc now so I can bolt the vg30 turbo on.
Uni's started back up so its finding the time. :P
This new years I'll be buying a GT30 SB8006A chra and .7 comp cover and have the vg30 turbine housing machined up to suit.
Should work well and be a little more efficient at higher boost levels due to the .7 comp cover.
how a turbo spins when its off the car and you spin it with your fingers is not a good indication of how free it spins!
depending on whether its new, used, has a bit of dust in the core, getting dry, etc... you'll find many second hand turbos that have been sitting wround a while to feel gluggy and not spin very well, but get them on the car and you'll hear them spin down after shut off.
i believe any half decent ball bearing turbo that has steel wheel will spin for some time after shut down. not so much the stock ceramic stuff, maybe not enough inertia in the wheels to keep them spinning for long after you turn off.
hey ppls.
BASS OUT
Hi Pete. I don't know if GCG uses these all the time buy they built mine with Ceramic Angular Ball Bearings.
Ian
So he revs it up, spins the turbo up and turns off the ignition which shuts off the oil pump/feed. Wow, really smart, hope he doesn't expect his turbo to last long :D
spinning it with your hand would be alot slower than it spins when being pushed by exaust gas. Also doing it once or twice with your fingers wouldnt matter, but doing it everytime you turn your car off, can't be good for it?
Not a great idea but these are more for longevity rather than response. The bearings add weight to the rotating parts. A good plain bearing should have no contact as it floats in the viscous oil pulled around the journal. It will not last as long though, but well cared for will give a good life.
I would gesss that most ball bearing turbos would have a small amount of pre-load in the bearing so that when it has been run for a while it comes within optimum tolerance. Heat would also play a factor as only .01mm difference would be needed to dramatically change how well it would spin.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
