Hey,
Some people have asked the schedule for this weekends Dutton Rally so that they can come down and watch (it's free to watch)
Friday 9:00am-12:00pm - DECA Shepparton
Friday 1:00pm - 4:00pm - Shepparton Airport
Saturday 9:00am - 4:00pm - Winton
Saturday 4:30pm - 6:30pm - SPC Carpark - Shepparton
Sunday 10:00am - 12:00pm - Essondon Airport Carpark
Sunday 1:00pm - 3:00pm - Police Training Centre - Atwood.
Basically that is the schedule for cars 48-96. On days one and 3 the schedule is swapped for cars 1-47. (As is cars 1-47 will do Shepparton Airport first then DECA)
But Myself and Scotsman (66), Blaise and Dan (67) and Frank and Aaron (68) are all in the 2nd group so will follow the exact schedule above.
As far as the events in Melbourne on the Sunday goes the stuff at Essondon is definitely the best to watch. Lots of great cars - 8 GTR's in total - plus a full range of Porkas (Twin turbo's, GT3's, GT2's and even a special Gemaballa Twin Turbo), as well as EVO's, STi's, BMW's etc etc.
:thumbsup:
https://www.sau.com.au/forums/topic/81931-dutton-rally-schedule/
Denham - it's where we did the Skidpan day with Kev.
It's ok - but watching cars go around in a circle is only so much fun. There is a little track there we have to do also thats brilliant fun to drive on but there's bugger all spots to watch it from so you don't get to see a whole lot.
Essendon is heaps better.
If anyone feels like driving up to Shepparton to spectate/drink (not to mention support the drivers and club) over the weekend we are staying at the Victoria Lake Tourist Park (check the Event Section fior more details).
Hope to see some of you around on the weekend.
:D
its pretty easy to get to.
for u just jump on ring road go around to tullamarine take that towards the city, then there is a turn off
as you come past westfield shopping centre etc, westfield will be on ur right and the airport and turnoff will be on the left.
as u come off the turnoff take the LHS sliplane and go straight.
then i have nfi where it is but im sure u can find it easy enough by the noise of the cars etc.
hope that helps
FRIDAY UPDATE
Rain interferred with play at DECA - with Snowcakes reporting 20s time differences between group 1 (dry) and his group (wet). The rain didn't hamper performance for group 1 at the airport - so they weren't disadvantaged at all.
The good news is the car isn't broken, and it's time to SARK PISS!
Apparently :rofl:
Winton tomorrow...
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
